Post by tootle on Nov 29, 2016 6:28:41 GMT
Hi all, after countless searching for an actual answer to the millions of "Offset" questions, I went downstairs and measured mine. So, drum roll please!!! My Rostyles appear to be an offset of +34mm. Now, before anyone gets too excited; - This isn't particularly accurate - could be plus or minus a couple.
- I read somewhere that the Rostyles are not actually the correct offset - TBC
- This isn't the end of the conversation when fitting aftermarket wheels, just the beginning. You'll still need to clear all hub parts (Caliper etc), and bodywork.
On the plus side, I'm pretty sure I've seen Jeep Grand Cherokee wheels in that offset. Off to play now.
Post by petrolhead allan on Nov 29, 2016 16:41:28 GMT
[/p] On the plus side, I'm pretty sure I've seen Jeep Grand Cherokee wheels in that offset.
[/quote] Somewhere in the Search function, there are details of which Grand Cherokee wheels will fit. A member posted this some time ago.
Post by Warwick on Nov 30, 2016 5:09:40 GMT
Post by Roy of the Rovers on Nov 30, 2016 18:05:05 GMT
Heres mine trial fitting a set of 17" Jeep Grand Cherokee wheels. They fit if you open up the centre bore of the wheel to match the P5 or fit small spacers. The rears snag the rear spring clamps without the spacers. Attachment DeletedAttachment Deleted
Post by tootle on Dec 1, 2016 23:30:26 GMT
Hi Roy,
what is your rim width? 7.5"
Post by Roy of the Rovers on Dec 2, 2016 15:35:20 GMT
Yes 7.5 width. You need the spacer on the rear to clear the springs but the front might be OK with the wheel centre machined. The spacers I have aren't great, I'd like to get some with spigot rings to fit the P5 hub and jeep centre exactly for safetys sake.
Online description: 2005-2007 Jeep Grand Cherokee
Size: 17" x 7.5", 5 Lug, 5" Bolt Pattern Finish: Machined and Silver Description: Used 5 Spoke OEM Alloy Wheel
More data: – Center Bore: 71.4 mm – Lug Size: 1/2" - 20 UNF – Wheel Fasteners: Lug nuts – Trim Production: [2005 .. 2010]
Tire 245/65R17
Rim 7.5Jx17 ET50.8
PCD 5x127
