thor64
Post by thor64 on Aug 20, 2019 18:55:12 GMT
Hi, what is the height of a rotor arm for a 1964 P5 Mark 2 coupe. The one in the car is 20mm in height and works with the original Lucas cap. Having had to replace the cap due to being unable to remove one of the screws I bought a reproduction cap to find that it will not fit over the 20mm rotor. Measuring the central coil pillar I found it to be 2mm longer than standard Lucas cap. I have been told rotor's 16.50mm high are available. Hence the conundrum what is the OEM height for this model car. Oh and I hope no-one says it depends on the distributor you use; as this could be getting more complicated than I expected. thor64
