Post by Sam Bee on Mar 21, 2021 18:24:20 GMT
Could well be thanks to pressure from the Federation of British Heritage Vehicle Clubs?
Post by stirlingmg on Mar 23, 2021 10:52:29 GMT
Since you’re all messing with your headlight upgrades, can I have all your old sealed beams please? My car is still fitted with its LHD headlamps from it’s time spent in France
Post by Mike’S-a-loon on Mar 23, 2021 12:58:39 GMT
Guess who is going to win the next concourse on originality?
Post by 3litrekiwi on Apr 10, 2021 6:28:52 GMT
I did a 1200 mile trip in February and was still running the original sealed beams. One night in the rain things got a bit scary so resolved to do something about an upgrade. It seems the jury is still out on LED's and it seems they are not legal here as an upgrade so I decided to go with a set of H4 halogens for the time being with relays.
The improvement in light is quite good but I have a query about the best place to pick up the power source. As Fuse 1-2 is fed by a nice fat cable and there was a spare terminal on the fuse box this seemed to be a safe choice however this seems to be problematic for the ammeter as rather than showing negative when the lights are switched on it goes a bit positive.
I could run a longer wire to the solenoid and draw straight from the battery but if possible would like to keep the wiring neat so figure there must be a suitable pick up from either the fuse box or voltage regulator.
MkIII 3 Litre, any suggestions?
Post by johnwp5bcoupe on Apr 10, 2021 8:37:26 GMT
Having a look at your wiring diagram Martin you have done all you can as far as I can see (no pun intended) you may have to go with the relay route with Halogen if you need to improve further or fit LED and swap when the time comes to be tested
Post by Phil Nottingham on Apr 10, 2021 13:00:56 GMT
The Battery A1-A2 load does bypass the ammeter but the dynamo charge does not. A fused cable to the starter solenoid is easy to do and the switch needs to be protected by a least one relay if Halogen in used.
The new MOT regs have been amended so LEDs are legal so long as the beam pattern is correct - I have them in our 3 Litre
Post by 3litrekiwi on Apr 10, 2021 20:14:22 GMT
Thanks guys, the regulations down here will likely catch up with the UK at some point re the LED's. Provided no damage is being done I'm not too concerned with the odd ammeter reading as the rest of the gauges require a bit of interpretation too!
Post by Phil Nottingham on Apr 10, 2021 20:47:51 GMT
No damage is being done but the console lighting switch needs at least 1 30A relay to avoid overheating it with halogens and even standard bulbs will suffer less from voltage drop
Post by 3litrekiwi on Apr 11, 2021 9:54:31 GMT
Thanks Phil, I have fitted two relays between the circuit to the fuse box and the fuses for each headlamp. The original cables that connected to the L/H side of the fuse box now connects to the relay solenoids and the new feed supplies the power to the lights via the original fuses.
Post by stirlingmg on Apr 11, 2021 10:02:59 GMT
I’ve still had no offers of any unwanted sealed beams🙂 cash waiting for a nice set of genuine Lucas 75 watters if anyone has any
Post by Phil Nottingham on Apr 11, 2021 11:23:32 GMT
The 75w versions have always been scarce! I am keeping mine on the P5B but they look dim now compared to the Leds on the P5. I have some spare 45/60w versions for the Land Rovers and the P4 but they are used so life left is variable
benedict_h
Post by benedict_h on Apr 11, 2021 12:56:08 GMT
I’ve still had no offers of any unwanted sealed beams🙂 cash waiting for a nice set of genuine Lucas 75 watters if anyone has any Changed sealed beams to Lucas Lub314 the other day. This is what came off: not Lucas, bit rusty and it says 'European' on the front. I am assuming you wouldn't want them..
Post by stirlingmg on Apr 11, 2021 16:15:51 GMT
Thanks but they’ll be for left hand drive
Post by Sam Bee on Apr 11, 2021 22:07:10 GMT
I have several originals. I shall attempt to test a pair. I will PM you with a result.
benedict_h
Post by benedict_h on Apr 12, 2021 7:14:45 GMT
Thanks but they’ll be for left hand drive No problem. I'm sure they will be of use to someone. Better give the artist a call right away actually
