Post by Dean Hovland on Nov 18, 2011 17:07:09 GMT
Ive decided to fit K&N filters to my P5B. What should i do with the other pipes and hoses that went into the origional filter box ?
Dean
Post by p5tgc on Nov 20, 2011 12:27:27 GMT
Do you still have an AED?
The vent from the AED float chamber can be re routed to ground, but the intake on the nearside elbow should be fitted with some form of filter, such as the small breather filters available. A similar breather / filter needs to be fitted to the manifold breather at the rear, (the fuel filter one).
Post by Pete Collins on Nov 20, 2011 19:36:25 GMT
Ive decided to fit K&N filters to my P5B. What should i do with the other pipes and hoses that went into the origional filter box ? Dean If you get the correct k&N filters they will fit into the original filter box and all will look as it should.
Post by Dean Hovland on Nov 21, 2011 9:44:26 GMT
AED ?
Post by johnwp5bcoupe on Nov 21, 2011 10:53:39 GMT
Automatic Choke or Automatic Enrichment Device.
Post by Dean Hovland on Nov 22, 2011 19:17:07 GMT
Thank you .
Ive received the K&N filters for the carbs and bought two small K&N filters for the other two pipes i have, that were connected to the what presume is the crankshaft housing. I dont have an automatic choke . Plan is to fit them tomorrow and do a test run
Post by Deleted on Nov 22, 2011 21:50:02 GMT
Post by Dean Hovland on Nov 23, 2011 3:44:50 GMT
Thanks crossplies , this actually has saved me a lot of work.
My plan to afix the small filters to the bulkhead has now been shelved . I will fix them as close as possible to the carb filters.
Post by Roy of the Rovers on Dec 7, 2011 18:53:35 GMT
You might need to rejet your carbs. I got quite a flat spot on acceleration after fitting k&n's
Post by Pete Collins on Dec 11, 2011 18:45:56 GMT
Ive decided to fit K&N filters to my P5B. What should i do with the other pipes and hoses that went into the original filter box ? Dean If you get the correct k&N filters they will fit into the original filter box and all will look as it should. The direct replacement for the P5B is K & N E-9098, just found the box. They are for sale on ebay for £26.61 each and you will need two. Or, the club now sells two Coopers air filters for £12 including P & P. No Vat TWO Coopers air filters for the P5B. £9.50p (NO VAT)Postage UK = £2.50 • Postage EU = £3.50
Post by Dean Hovland on Jan 13, 2012 19:48:02 GMT
I fitted two RC 2600 and two crankcase filters the shop had on the shelf , these i made fit by buying new hoses . The 2600 are chromed and look better then the big old filter box, i need to make a bracket for the accelerater cables .. a job when im back in Norway and its not minus. I drove the car for a short run ,it seemed alot more responsive idled better and sounded better.
Dean
Post by eisdielenbiker on Feb 7, 2012 7:38:43 GMT
You might need to rejet your carbs. I got quite a flat spot on acceleration after fitting k&n's Hi, did you fit them inside the original box ? Mark
Post by eisdielenbiker on Feb 7, 2012 11:47:16 GMT
I see. Do you think the sound has improved, too ? I did not notice any flat spot as 'Roy of the rovers' got.
Mark
gollop
Post by gollop on Feb 8, 2012 7:02:38 GMT
Sounds a bit more grunty. Not sure about the flat spot but will report back in a couple of days.
Post by Dean Hovland on Feb 8, 2012 7:10:53 GMT
I see. Do you think the sound has improved, too ? I did not notice any flat spot as 'Roy of the rovers' got. Mark Hi Mark Heading through Hamburg on the way to Hirtshals tomorrow . Whats the weather like your way ? Im in Bilbao now Paris later today... The KN s i fitted enhanced the v8 burble imho. Couldnt detect any flat spots and the car starts better
Post by eisdielenbiker on Feb 10, 2012 8:04:27 GMT
Hi, hope you have arrived well. The weather delivered snowfalls t around 0 degrees which converted quickly into a muddy mess. Meanwhile harsh frost has reengaged. You didn't drive the P5, really ? Regards Mark
Post by Dean Hovland on Feb 10, 2012 9:49:04 GMT
Hi Mark No the P5B is in Norway. Plan to bring her down in the summer ,,, or get the ferry from Bergen til Newcastle , then ferry from Portsmouth to Bilbao. Depends on the ferry routes. Im in a hotel at Bad Bramstadt , whilst winter tyres get fitted to my Touran. :-O -11 in Belgium yesterday -9 most of the way til Hamburg then it was a balmy -3. Hamburg was clear of traffic first time ive seen it that good guess they only dig the roads up for the tourist in the summer.:-) Dean
