Post by eightofthem (Andy) on Jul 18, 2013 14:47:26 GMT
Well done. Nice looking car. Dorsetflyer will be smiling.
Post by Chuck Berry on Jul 18, 2013 14:51:09 GMT
Post by norvin on Jul 19, 2013 7:10:16 GMT
XJD is my 1968 saloon at the mid Lincs rally!.
mh007
Post by mh007 on Jul 19, 2013 9:48:19 GMT
Am I missing something ?
I can only see the post above this one & no other post or pictures !
Post by johnwp5bcoupe on Jul 19, 2013 11:00:31 GMT
Am I missing something ? I can only see the post above this one & no other post or pictures ! There was a double post so I deleted one so I hope this is easier to follow
Post by GlennR on Jul 19, 2013 12:05:36 GMT
Hi Chuckles, John Andrews (DorsetFlyer) is on the far right in this photo.
Post by David on Jul 19, 2013 12:39:08 GMT
By coincidence a picture of the car will be in the next issue of Take Five (page 3) Chuckles, I have sent you a couple more photos by email.
Post by PeterMadden on Jul 19, 2013 14:19:07 GMT
John would be delighted to see his car back at rallies and on the forum. He was a regular and knowledgeable contributer and took in many rallies. He used to come up as far as Classics on the Common in Harpenden in the early days and that was a fair old trip for an evening event. I think he'd also be happy to see his car remaining in Dorset!
Post by GlennR on Jul 19, 2013 20:21:44 GMT
Nicely said Pete
Post by Chuck Berry on Jul 22, 2013 19:37:41 GMT
John would be delighted to see his car back at rallies and on the forum. He was a regular and knowledgeable contributer and took in many rallies. He used to come up as far as Classics on the Common in Harpenden in the early days and that was a fair old trip for an evening event. I think he'd also be happy to see his car remaining in Dorset! Thank you for those kind words. All being well I hope to continue in the same vane.... it has started with the Sherborne show this last Sunday and hopefully to meet up at the Fox & hounds at Canford on Monday 5th. is that correct?
Post by Chuck Berry on Jul 30, 2013 18:02:52 GMT
Lovely to see a picture of John, the Dorset Flyer.
The badge bar is now nearly populated with my old badges found in a distant cupboard somewhere! It tooks some cleaning but they are looking good.
At last the rev counter is now working. I did gain an extra rev counter but it lied.... it was showing 1500 revs at tickover, and managed to be about 1000 revs proud all the time. So while the old one was out of the car it gave me time to do some cleaning and a few drops of watch oil and wey-hey!
The gearbox is not doing so well, changed the oil and cleaned the filters - its a bit better, but a full repair is on the cards. I am going to keep a lookout for a MkIII basket case as a doner.
Post by norvin on Jul 30, 2013 18:23:47 GMT
sorry about your gearbox so will you fit the later engine with the BW 35 box.
Post by Chuck Berry on Jul 30, 2013 23:11:23 GMT
If one comes to hand, quite possibly, as they would be matched on the crankshaft. I gather there is quite a difference in the crank and with the later BW-35 box, a higher compression engine would be better suited and improve overall performance.
Hopefully if I can find a MKIII that has a reasonable or rebuildable engine and gear box that would be the answer. As a bonus if it had better front seats, the same colour as the existing, and they have the headrests, even better..... and..... if there was a heated rear screen.... but that would be over the top a bit!
But you never know........
Post by Phil Nottingham on Jul 31, 2013 21:45:39 GMT
The Mk3 onward seats are not as good though and it would not be original any more with the wrong power unit and seats
Post by allanthomas1 on Aug 1, 2013 3:18:10 GMT
Can I point out that I had a Mk2 rover 3 litre with a DG box, I successfully replaced the DG auto with a BW 35auto from a mark 3, you cannot fit a manual gearbox because there is a difference between the crankshaft on the auto equipped cars and the manual cars. Also the later MK3 had a 3.54 ratio axle instead of the 3.9 ratio fitted to cars equipped with the DG auto.
Allan Thomas
Post by Chuck Berry on Aug 1, 2013 5:38:58 GMT
Wow! it looks like I have been taken to task here!! I only wanted headrests and the picnic table behind the seat...
Allan, Are you saying the BW35 will directly fit the MkII engine with a DG Box?
That axle ratio difference....3.54 ratio axle instead of the 3.9, can you clear my thoughts on this. Given a road speed, is that higher engine revving if I use the BW35? Speedo readings come to mind as well.
Just to throw another spanner in the works... The rev counter I acquired that was a bit ambitious on the rev counting (about 1000 to many). I intend to convert from Positive earth to Negative earth, for many reasons. Is there somewhere that can service/repair the Tacho, and convert it to Negative earth?
Post by harvey on Aug 1, 2013 12:16:59 GMT
That axle ratio difference....3.54 ratio axle instead of the 3.9, can you clear my thoughts on this. Given a road speed, is that higher engine revving if I use the BW35? Speedo readings come to mind as well. If you just change the BW35 for the DG then the engine RPM at any given speed will be the same. If you change the 3.9 diff for the 3.54 then the engine RPM will be lower at any given speed. (Higher numerically = lower ratio, and vice-versa). If the BW35 is a direct bolt in replacement for the DG then I'd do it in a heartbeat. Just make sure you use a P5 BW35 (5 position selector) not a P5B (six position selector) box. If you wanted to use the latter you'd have to fit the P5B tunnel cover and gearlever. (Which I would assume isn't a problem).
Post by allanthomas1 on Aug 1, 2013 13:18:21 GMT
Sorry if you get the impression I am taking you to task here, the mark 3 rover 3 litre had the gear selector on the steering column as well it is a question of using all the parts from a MK3 3 litre, I would suggest contacting David Green to see if he is breaking a Mk3 Auto and do a deal on the parts, if you were to go down the road of fitting the tunnel from a 3.5 V8 you could then fit the 3.5 Litre box using the linkage from a 3.5 rover, the 35 box is a good conversion. I covered over 70,000 miles in my Mk2, I could be wrong here but is the BHP figure the same for the Mk2 and Mk3 121BHP.
Hope this is helpful
Allan
Post by Chuck Berry on Aug 1, 2013 20:21:03 GMT
If I did change I would want to keep the column change, even if it means juggling about with the decal. I just love the little ring pointer. Not too keen on the tunnel changer though.
I don't think I will be going so far as changing tunnels, but I will contact David Green, I gather he is a dealer or a chap that knows about things. Excuse my ignorance but I am still learning who's who here. How do I contact him?
I think I have the ratio's clearer in the old bonce, so now it’s a case of finding a suitable replacement gearbox, or having the existing overhauled but that is about £1200 locally! (possibly more at this rate)!
I am in no rush as the car is still mobile, but as soon as a replacement is found then its into the workshop, possibly for the winter. The works will include some paint and minor body repairs as well as curing several leaks on the lower deck
Post by Chuck Berry on Aug 6, 2013 12:21:46 GMT
David Green?.... are you out there? ....how do I contact you?
Post by Welsh Warlock on Aug 6, 2013 14:32:57 GMT
Post by johnwp5bcoupe on Aug 6, 2013 14:34:33 GMT
David Green?.... are you out there? ....how do I contact you? He has a full time job so evenings and weekends Tel: 01284 788269 Mob: 07713785619 email: green.david10@sky.com web: www.davidgreen-p5.co.uk
Post by Phil Nottingham on Aug 6, 2013 17:03:07 GMT
Post by Chuck Berry on Aug 6, 2013 17:05:07 GMT
Thank you one and all; I didn't realise he had a web site.... live and learn, eh!
Post by Chuck Berry on Aug 6, 2013 17:12:23 GMT
I tried to remove the quote as many of you replied, anyway thanks for your help. I have sent him a mail from the site.
