Post by gilbern on Nov 1, 2013 12:42:34 GMT
Hi all, just bought my very first Rover : P5B.( 1970 Saloon: Burnt Grey colour ) I drove it home yesterday through London traffic. I got a few thumbs up & waves from other road users. I took my wife out in the car last night & we are both very happy with the car & the excellent ride. However I have noticed a few minor points ( it's 43 year old, so I do expect issues)
1. All the gauge lights are very dim....ie: cannot read them at night : I have tried to alter the setting on the dashboard switch : after reading the owners manual last night. 2. I have no screen washers either.
Before I get the bonnet open with a volt meter & start checking, I thought I would ask for help on here first.
Thanks Julian
Post by Simon H on Nov 1, 2013 15:38:57 GMT
Hello Julian and welcome to the fold... I bought my first ever P5B in September and no doubt you're on a similar learning curve to myself. I am happy enough tinkering with Rover V8 engines but the rest of the car is new to me. However, I can offer a tip with regards your screen washers. Do you still have the original Trico washer bottle with the grey lid with integrated pump? Does the motor get 12 volts and a good earth but doesn't go? If so you might be able to coax it back into life by following these steps:
1. Unscrew the washer bottle lid and invert it so that you can see the 'other' end of the pump.
2. Carefully undo the 2 Philips screws on the end of the pump and carefully remove the end cap taking care not to damage any seal that may be fitted.
3. You can now see the impeller that is the business end of the pump. (In reality it's just a little rubbery star shaped thing on the end of the motor shaft)
4. Clean out any grot with a suitable brush and warm soapy water. (DON'T use WD40 or similar as it may well end up on your windscreen...)
5. Clean up the end cap and seal.
6. Using a pair of blunt tweezers or small pointed nose pliers GENTLY try to turn the impeller. With a bit of luck it will turn. If not, then you might have to be not so gentle - just bear in mind the fragile state of the rubbery impeller.
7. Assuming that the impeller turns by hand, give it a go on the the push button. It won't do any harm for the motor to run without pumping anything - in fact will will give it a bit of exercise!
8. Use a bit of screen wash as an assembly lubricant and put the end cap & seal back on. DO NOT over tighten!
9. With a bit of luck the job is a good 'un!
Let us know how you get on!
Simon H
Post by Phil Nottingham on Nov 1, 2013 18:17:14 GMT
Gauge lighting is dim but more so if the dimmer switch slider is corroded or the bulbs blackened. I replace mine with Leds - special MES versions.
Plenty on SEARCH with this
Post by newboy on Nov 2, 2013 1:02:35 GMT
Gauge lighting is dim but more so if the dimmer switch slider is corroded or the bulbs blackened. I replace mine with Leds - special MES versions. Plenty on SEARCH with this Hi Phil, could you post a link to where you bought the LED's please and the codes/sizes etc. thanks in advance.
Post by Phil Nottingham on Nov 2, 2013 9:36:23 GMT
Post by gilbern on Nov 21, 2013 14:00:21 GMT
Thanks Phil: The gauge lights have improved with some work & I have replaced the bulb in the drive selector.
Thanks Simon: followed the instructions (cleared out the almost solid mass of sludge in the bottle) & overhauled the electrics. They now all working fine.
Rainxed the front windscreen too.
I used the car for yesterdays commute. Its driving fine apart from the 1st cold start. That needs careful use of the choke to keep running & not stall when drive is engaged. I think it just called "character" of the car. It makes me smile as I glide through the traffic. Definitely a car to be used & enjoyed.
Julian
Post by nigelb on Nov 21, 2013 15:27:20 GMT
How many MES,BA7 and BA9 bulbs do you need to do all of the dash and lower dials
Post by Phil Nottingham on Nov 21, 2013 18:40:08 GMT
Off- hand I cannot remember but its on Search
benedict_h
Post by benedict_h on Sept 21, 2019 20:17:22 GMT
How many MES,BA7 and BA9 bulbs do you need to do all of the dash and lower dials Hi Found this checklist in my Evernote archive: bonnet (2) capless w2.1x9 5W capless warm white done boot (1) Bayonet 9 mm 4W ATAT 4W IE412EG warm white done gear change (1) 36 mm festoon festoon white done courtesy lights (4) 38 mm festoon festoon warm white done switches (4) BA7s white done speedo + tacho (2) E10 MES E10 warm white done instruments coupe (4) E10 MES E10 warm white Done reverse light (1) Bayonet 21W warm white done licence plate illumination (2) Bayonet 9 mm 5W warm white done handbrake (1) BA7s white check > too bright rear heater (1) BA7s white done side lights (2) 0,9 mm 5W warm white done brake / tail (2) Bayonet 21W / 5W warm white done clock (1) BA7s white done warning lights oil + alt (2) E10 MES warm white to do on order Rgds Benedict
