Post by Chuck Berry on Jul 31, 2014 15:57:32 GMT
I need a pair of rear springs or at the least have the existing re-tempered.
I favour buying new, unfortunately the only source at present appears to be JRW with some 'Heavy Duty' ones, and they are on holidays so not sure if they are in stock.
I am going to replace the lot - but all I have at present the the rear bushes!
Post by djm16 on Jul 31, 2014 16:12:25 GMT
A couple of tips. 1) do not let the rear axle dangle from the springs for a prolonged period (put axle stands under the rear axle) or the Y bush will shear apart. 2) check the rear locating hole in the spring is in the right place. I had to extend the hole o a slot in order not to distort the Y bushes at rest.
Post by enigmas on Jul 31, 2014 19:18:03 GMT
Also look at fitting a set of 'poly-air' boosters. These units are a low pressure air bag that fits just in front of the axle. A bicycle pump is all that is required. I've had a set on my coupe for over 20 years.
Post by Deleted on Jul 31, 2014 21:10:40 GMT
There is a place in Portsmouth that can recondition springs. They are very good had some transit ones done there a few years ago. Made all the difference
Post by barryr on Jul 31, 2014 21:59:58 GMT
I've found a place near me in Coleshill that will recon springs too. Not ready to do them yet as I like the ride height but they will need doing.
Post by enigmas on Aug 1, 2014 12:17:18 GMT
Post by djm16 on Aug 2, 2014 9:36:17 GMT
Oh,OH! thats me!
Post by barryr on Aug 4, 2014 21:26:41 GMT
Cripes more research before I touch that project I think!
Post by Chuck Berry on Aug 8, 2014 7:18:14 GMT
Thanks for all the info.... I have now the leaf springs, bolts bushes.... the complete (new) kit!
All I have to do now is fit them!
No Rest for the wicked (or the good ones.......)
Post by Deleted on Aug 8, 2014 10:32:29 GMT
Thanks for all the info.... I have now the leaf springs, bolts bushes.... the complete (new) kit! All I have to do now is fit them! No Rest for the wicked (or the good ones.......) Chuck, where did you get the springs?
Post by Chuck Berry on Aug 8, 2014 21:45:50 GMT
Thanks for all the info.... I have now the leaf springs, bolts bushes.... the complete (new) kit! All I have to do now is fit them! No Rest for the wicked (or the good ones.......) Chuck, where did you get the springs? I bought the whole lot from a member of our wessex group. He had purchased them to fit to a car but never did. They all came from JRW. Hope that helps
Post by Deleted on Aug 9, 2014 8:56:27 GMT
Chuck, where did you get the springs? I bought the whole lot from a member of our wessex group. He had purchased them to fit to a car but never did. They all came from JRW. Hope that helps Thanks Chuck.The reason I asked is that I think JRW is the ONLY supplier of rear springs and I know he's on holiday at the moment. I thought you may have found another source. The fitting will be an interesting thread when you get started.
Post by Chuck Berry on Aug 9, 2014 15:59:24 GMT
I think that you're correct, JRW are the only suppliers of new springs. I have heard it said that todays spring temperers are not as good as the old'ns! they do not hold the rating very long, so as I do not want to do this again I opted for new.
I am hoping to get started in about two weeks after some R&R if I am lucky!
Post by Chuck Berry on Aug 9, 2014 16:15:17 GMT
You can see by this why I need new springs!
Post by enigmas on Aug 10, 2014 0:03:00 GMT
Post by Steve P5b on Aug 10, 2014 7:47:53 GMT
That's a very nice neat set up you have there Vince,I had a search and couldn't find a supplier here. Are they still available in OZ I did find these though air-suspension.co.uk/products.html they are for small commercials they could be altered with different brackets for rovers maybe. Or even replace the "cart spring" we all have completely for a extra comfy ride.
Post by enigmas on Aug 10, 2014 9:45:10 GMT
Yes, they are still available in OZ Steve. There's a link at the bottom of the last photo that has contact details of a dealer. The version you're looking at is about double the price of the red Polyairs.
Cart springs certainly is the right term for the rear suspension of a P5. A 4 bar rear link system incorporating a panhard rod and air suspension on the rear would make a world of difference to the ride quality and handling.
Post by Chuck Berry on Aug 10, 2014 13:41:51 GMT
I haven't started yet but now in a quandary!
It was said that ‘at-rest’ no load and empty that the back end does sag, strangely even with a nose weight of 75kg the ride height doesn't alter, maybe an inch - no more. This leads me to think that there is little "spring" left in the leaf springs - hence the replacement program. Certainly the drive train angles determine some attention, but I do take the point that the rear may be up a bit more than is desirable and may be harsher as the springs are labelled "heavy duty".
I am hoping that towing with an increased nose weight that the new springs will settle quickly. I am familiar with air ride assisters and yes they do what they are supposed to.
So now what? I will persevere with replacing the springs as they are over 50 years old, all the bushes are completely shot so at least some good may come of it. Watch this space as they say and see what the outcome will be. I think it will be a project for sometime in September at the moment with all that’s’ going on at present.
Post by Deleted on Aug 10, 2014 14:13:29 GMT
I haven't started yet but now in a quandary! It was said that ‘at-rest’ no load and empty that the back end does sag, strangely even with a nose weight of 75kg the ride height doesn't alter, maybe an inch - no more. This leads me to think that there is little "spring" left in the leaf springs - hence the replacement program. Certainly the drive train angles determine some attention, but I do take the point that the rear may be up a bit more than is desirable and may be harsher as the springs are labelled "heavy duty". I am hoping that towing with an increased nose weight that the new springs will settle quickly. I am familiar with air ride assisters and yes they do what they are supposed to. So now what? I will persevere with replacing the springs as they are over 50 years old, all the bushes are completely shot so at least some good may come of it. Watch this space as they say and see what the outcome will be. I think it will be a project for sometime in September at the moment with all that’s’ going on at present. Now that you've got the springs, I would carry on and replace them if I was in your position.From memory,the JRW spring leaves are much thicker with fewer leaves and no inserts so you're going to have a harsher ride. Perhaps some heavy duty rear shockers might help(more expense!) I would also force open the leaves and fill every surface with CV grease.
Post by norvin on Aug 10, 2014 15:50:19 GMT
I also bought some springs for my P5B from someone who bought them from JRW but never used them, my springs were well down at the back, anyway after fitting them the back of my car was so high it looked like a drag car and when I sat in it and looked in the wing mirrors all I could see was the sky. I took out two leaves from each spring and the car sat and rode perfect.
roverp5b
whats in your mirror
Post by roverp5b on Aug 10, 2014 16:43:04 GMT
Post by Deleted on Aug 10, 2014 18:40:52 GMT
I also bought some springs for my P5B from someone who bought them from JRW but never used them, my springs were well down at the back, anyway after fitting them the back of my car was so high it looked like a drag car and when I sat in it and looked in the wing mirrors all I could see was the sky. I took out two leaves from each spring and the car sat and rode perfect. How many leaves were left? Wouldn't that be a cause for concern and an insurance issue?
Post by norvin on Aug 10, 2014 19:23:25 GMT
I think it was 5 leaves left, but this is years ago not last week.
Post by Steve P5b on Aug 11, 2014 3:09:13 GMT
Post by Steve P5b on Aug 11, 2014 3:21:01 GMT
Yes, they are still available in OZ Steve. There's a link at the bottom of the last photo that has contact details of a dealer. The version you're looking at is about double the price of the red Polyairs. Cart springs certainly is the right term for the rear suspension of a P5. A 4 bar rear link system incorporating a panhard rod and air suspension on the rear would make a world of difference to the ride quality and handling. I never realised this idea had been around for so long until I stumbled on this:- www.speedhunters.com/2014/05/know-real-history-air-suspension/
