Post by Dean Hovland on Aug 23, 2014 7:36:11 GMT
Mine is stuck on full tilt .
Post by Phil Nottingham on Aug 23, 2014 9:12:50 GMT
There a quite a number of threads on this topic
Post by johnwp5bcoupe on Aug 23, 2014 13:11:36 GMT
Dean if it's stuck all the time it will be a mechanical problem ie lack of lubrication? little pinion broken? spring broken? if it returns when the engine is switched off probably dried out capacitors or another component failure? Good Luck
Post by Dean Hovland on Aug 23, 2014 14:00:38 GMT
There a quite a number of threads on this topic Where do i find them please ? Ive tried ; rev counter , rev , revs and counter in search
Post by johnwp5bcoupe on Aug 23, 2014 14:08:46 GMT
Post by Dean Hovland on Aug 24, 2014 7:07:34 GMT
Thank you
Post by Phil Nottingham on Aug 24, 2014 7:40:23 GMT
SEARCH Rev counter with "all the words" gives 21 pages of hits!
Post by Warwick on Aug 24, 2014 10:34:06 GMT
Phil, Does Search still not accept anything with less than 4 characters? For example gas, lpg, rev, etc.?
Dean, My tacho reads high and I discovered awhile back that it's affected by the Facet fuel pump. The tacho reads 500 RPM, with the ignition on but the engine not running.
Post by Phil Nottingham on Aug 24, 2014 17:36:07 GMT
Odd - I used to get that sometime ago now before I used Google Chrome. It searches OK now
