ANDY CAPP
Post by ANDY CAPP on Sept 2, 2014 12:12:33 GMT
Can anyone tell me where i can get a set of chrome nut's from, what thread are they,whitworth or AF, are they 7/16th, and is the taper 60 degree's, if this is right,i have seen various on ebay at £35 a set. Help! Thank's. Mick.
Post by guidedog on Sept 2, 2014 13:29:09 GMT
Can anyone tell me where i can get a set of chrome nut's from, what thread are they,whitworth or AF, are they 7/16th, and is the taper 60 degree's, if this is right,i have seen various on ebay at £35 a set. Help! Thank's. Mick. J R W chrome @ £2.75 or stainless @ £3.50 each delivery & VAT
Post by Deleted on Sept 2, 2014 13:31:16 GMT
Can anyone tell me where i can get a set of chrome nut's from, what thread are they,whitworth or AF, are they 7/16th, and is the taper 60 degree's, if this is right,i have seen various on ebay at £35 a set. Help! Thank's. Mick. The socket size is 3/8w. These images might help and they show the difference between the original nuts and the new ones currently available from JRW. I have replaced all mine and they're fine but "dig" in more to the nut recess because the shadow profile is the same shape but shallower on the new nuts so the flats start to bear on the recess sooner. I don't know about any other source of wheel nuts but I suspect the profile will be different than original and I haven't ever seen NOS available. Too shallow a profile might be dangerous.
Post by davewright on Sept 2, 2014 13:37:01 GMT
I would be wary of stainless steel nuts. I see this advertised usually as for show use which would suggest they are not suitable for normal road use. I believe the tensile strength of stainless is relatively low. Perhaps someone could confirm if I am right.
Post by Warwick on Sept 2, 2014 14:17:39 GMT
I think the main problem with stainless steel nuts and bolts generally is that they are much harder that ordinary carbon steel, and the threads tend to bind. Stainless on stainless is worse. I think the problem is that if you did them up tight, you may not get them undone again without breaking the stud or damaging the thread. The binding action is called galling.
Post by eisdielenbiker on Sept 2, 2014 14:33:58 GMT
the chrome nuts tend to peel at the edges very soon if used every now and then. next time i possibly prefer stainless steel.
Post by johnwp5bcoupe on Sept 2, 2014 14:39:08 GMT
I think the main problem with stainless steel nuts and bolts generally is that they are much harder that ordinary carbon steel, and the threads tend to bind. Stainless on stainless is worse. I think the problem is that if you did them up tight, you may not get them undone again without breaking the stud or damaging the thread. The binding action is called galling. Galling is a problem Warwick if the threads are tight ::)but can be avoided if the threads are lubricated slightly with Copaslip Nothing wrong with SS in the compression mode you just have to be "careful" if used in the shear mode best avoided if you aren't aware of what the grade properties are!
Post by Warwick on Sept 3, 2014 3:38:11 GMT
John, I'm also forgetting that stainless steel bar stock probably comes from China these days.
Post by eisdielenbiker on Sept 3, 2014 8:02:35 GMT
John, I'm also forgetting that stainless steel bar stock probably comes from China these days. So are possibly the chromed wheel nuts. No proper layer build up in professional terms I would say. Galling is an interesting point so lubrication will help. Good advise...
ANDY CAPP
Post by ANDY CAPP on Sept 3, 2014 16:58:19 GMT
Thank's everyone for your replies, i have an idea that mini nut's might fit, i hope so as they are only £1 each as apposed to JRW's £3.50.
Post by johnwp5bcoupe on Sept 3, 2014 17:17:32 GMT
Thank's everyone for your replies, i have an idea that mini nut's might fit, i hope so as they are only £1 each as apposed to JRW's £3.50. Are they not 3/8" unf not 7/16" Mick ?
Post by Deleted on Sept 3, 2014 19:33:12 GMT
Proper minis (not the BMW contraptions) have 3/8 unf wheel nuts. Be a bit careful of ordering from a couple of places on ebay,who according to their listings seem to regard imperial and metric threads as interchangeable.
ANDY CAPP
Post by ANDY CAPP on Sept 3, 2014 21:11:20 GMT
Thank's everyone for your replies, i have an idea that mini nut's might fit, i hope so as they are only £1 each as apposed to JRW's £3.50. Are they not 3/8" unf not 7/16" Mick ? Thank's for replying, on another thread from 2011, someone say's that the Rover nut's are 3/8" another say's 7/16", so i dont really know what to look for, Help !
Post by harvey on Sept 4, 2014 13:26:32 GMT
Are they not 3/8" unf not 7/16" Mick ? Thank's for replying, on another thread from 2011, someone say's that the Rover nut's are 3/8" another say's 7/16", so i dont really know what to look for, Help ! 3/8" Whitworth spanner size, 7/16"UNF thread size.
ANDY CAPP
Post by ANDY CAPP on Sept 4, 2014 16:01:38 GMT
Thank you for that, i think i am going to buy the £31 option from ebay, and if they dont seat as well as i want i will machine them to fit. Cheer's . Mick.
