Post by norvin on Oct 20, 2014 12:21:43 GMT
Has anyone tips on making new door pockets, we do not have access to a sewing machine is it possible to just glue it all. I took them to a seamstress who is only around the corner from me and I think she did a good job I have not glued them on yet. The small black things are what hold the bottom of the pockets onto the door card does anyone know if I can buy any new ones.
win53
real rookie but willing to learn with help
Post by win53 on Oct 20, 2014 14:01:57 GMT
Hi Norvin JRW do Map Pockets. You can either buy a new pocket by sending your one back and they will return the new one with your choice of colour for £55 +VAT or you can get the Map Pocket Gloves (pocket without the metalwork) for £38 +VAT if you cannot use a machine. I have not yet made my mind up as to which way i will go with either the Glove or Map Pocket as mine need seeing to aswell
Colin
Post by norvin on Oct 20, 2014 14:26:13 GMT
Hi win53, thanks for the advice but when I bought my new carpets (from JRW) I also bought the material to cover my kick panels and enough for the door pockets so really need to use what I have as it's not cheap to buy.
Post by Welsh Warlock on Oct 20, 2014 15:58:18 GMT
Norvin, you will need to sew BUT, if you can strip your old door pockets and take them to a local seamstress I'm sure they'd be able to do the necessary sewing as it doesn't need much.
Post by norvin on Oct 20, 2014 18:14:05 GMT
Norvin, you will need to sew BUT, if you can strip your old door pockets and take them to a local seamstress I'm sure they'd be able to do the necessary sewing as it doesn't need much. Thanks thats a good idea.
Post by johnwp5bcoupe on Oct 20, 2014 18:31:45 GMT
Post by norvin on Oct 20, 2014 18:57:44 GMT
Thanks for the photos and info John I take it that the hinges are the bits on the ends which is the same as the door cards but they are not fixed to the door cards are they ?
Post by johnwp5bcoupe on Oct 20, 2014 19:01:41 GMT
Thanks for the photos and info John I take it that the hinges are the bits on the ends which is the same as the door cards but they are not fixed to the door cards are they ? Only by the Elastic Brian which goes through the Eyelets in the cards and are joined together by the shaped wire on the rear of the cards.
Post by norvin on Oct 20, 2014 19:39:24 GMT
Got it thanks John.
Post by Welsh Warlock on Oct 21, 2014 15:56:07 GMT
When I did mine I don't remember them being particularly difficult (But then i didn't do the sewing - I have a wife for that )
Post by norvin on Oct 29, 2014 11:40:45 GMT
See update.
Post by johnwp5bcoupe on Oct 29, 2014 13:12:33 GMT
Hi Brian you will have to do a Google for BIFURCATED RIVETS or SPLIT RIVETS there are some on Fleabay you will just need the correct dia x length Keep up the good work I hope those tight seams stick down ok
Post by norvin on Oct 29, 2014 17:00:13 GMT
Thank you John for the info on the rivets to be honest I have never heard of them. I found some on ebay so have ordered some.
Post by johnwp5bcoupe on Oct 30, 2014 6:48:47 GMT
Thank you John for the info on the rivets to be honest I have never heard of them. I found some on ebay so have ordered some. Result Brian
Post by norvin on Nov 21, 2014 14:11:08 GMT
Post by johnwp5bcoupe on Nov 21, 2014 15:52:03 GMT
Hi Brian it doesn't look right at the bottom hinge? it's hard to tell from the pics I wish you were a bit closer so I could come and give you a hand it would make a change from doing my Bro In Laws 60' Narrow Boat
Post by norvin on Nov 21, 2014 19:03:13 GMT
Post by johnwp5bcoupe on Nov 21, 2014 20:11:58 GMT
PM sent Brian
Post by Ken Nelson on Oct 3, 2021 22:52:37 GMT
I'm redoing the map pockets on the front doors of my P5 Coupe and don't understand how the long thin metal strip is supposed to be attached to the large outer piece of the pocket at the bottom. There are holes along the metal strip, but none in the outer piece, which it appears is only held against the door card by the elastic attached to the expandable vinyl. Any pictures, or explanation? Thanks
Post by johnwp5bcoupe on Oct 4, 2021 7:51:36 GMT
I'm redoing the map pockets on the front doors of my P5 Coupe and don't understand how the long thin metal strip is supposed to be attached to the large outer piece of the pocket at the bottom. There are holes along the metal strip, but none in the outer piece, which it appears is only held against the door card by the elastic attached to the expandable vinyl. Any pictures, or explanation? Thanks Bifurcated Split Rivets hold the pockets to the door card they go through the inner Moquette then the steel strip then the outer Moquette and finally the card where they are bent over and hammered in place. The two Vinyl hinges are held to the card by wire and the elastic goes through the two metal eyelets and meet at the rear of the card with a shaped wire. This is the only pics I can find at the moment OOPs just looked at previous posts
Post by Ken Nelson on Oct 4, 2021 13:02:11 GMT
Thanks John!
