Post by richardlamsdale on Mar 3, 2015 17:18:56 GMT
Richard, There are 2 special washers underneath the manifold bolts which have a small hole to fit the spring. I believe your spring is not the right one being too long. Peter Hi Peter, yes I have the washers with the spring hole, located under the third-from-rear manifold bolts, as per the manual. They align perfectly for the carburetter springs. I also have new springs from Wadhams, which were identical to the ones already fitted, so I'm sure they're the right length. But the washers are still too near the accelerator pivot point on the manifold to pull the cable back with any force, and in fact it actually assists the throttle opening slightly over the last ½ travel. As the accelerator pivot lever is directly linked to the kick-down lever, it makes sense to me that the spring mounts there instead - mine was missing this, hence the soggy accelerator pedal.
Post by richardlamsdale on Mar 3, 2015 17:26:33 GMT
Post by harvey on Mar 3, 2015 18:37:39 GMT
Post by Colin McA on Mar 3, 2015 23:30:16 GMT
Used to be cheaper. But they were well made, Ian only got things re manufactured if he could do it right.
Mine has done a few thousand miles will out complaint.
They should also have the air filter locating gromits which are nice to have.
Colin
Post by richardlamsdale on Mar 5, 2015 20:26:42 GMT
'Kick-down lever bush' arrived today and fits very well. I was surprised that it's so soft - it is basically a shaped grommet, so I'd expect it to wear very quickly, but we'll see. Can't help thinking nylon or brass would be better, but if it's the same as the factory fitted then at least it's original! Also fitted a spare spring from the carb on the kick-down lever - seems about the right length. I'll see how it all works at the weekend.
Post by Colin McA on Mar 5, 2015 23:43:22 GMT
Mine has been fitted for over 6 years and haven't seen any wear.
There isn't really any pressure on the bush and it only supports the end of the road and the kickdown cable.
The bronze bush on the manifold has to deal with the load from the carbs and the accelerator cable. I recon if it needed a tougher bush rover would have made it that way.
Colin
Post by richardlamsdale on Mar 6, 2015 18:37:05 GMT
True. It fitted fine and I refitted the kick-down bracket today - all seems to work well.
Post by v8pete on Feb 28, 2017 19:18:13 GMT
From above. From behind ( courtesy of CYF ) you can see where the bush should go ( red circle ) and how the spring is set up. ( the blue square shows the kick down cable ) Does anyone have the part number for the spring in the picture please OOOOH Andy an AED
Post by eightofthem (Andy) on Feb 28, 2017 20:29:36 GMT
I will have a look in the parts book, but I doubt it will help you find one from a supplier.
Places like machine mart etc sell packs of springs, I am sure you could find one to do the job just as well.
Post by harvey on Feb 28, 2017 20:49:57 GMT
The spring isn't shown in the P6B parts book that I've got.
Post by Warwick on Mar 1, 2017 1:25:30 GMT
V8pete, I'm confused. This is a 2 year old thread. Are you looking for a cable? You didn't actually say anything.
Post by eightofthem (Andy) on Mar 1, 2017 10:03:59 GMT
V8pete, I'm confused. This is a 2 year old thread. Are you looking for a cable? You didn't actually say anything. You did a man look Warwick : )
Post by v8pete on Mar 1, 2017 19:58:46 GMT
It's the late type kick down spring that is missing from my car sorry if I wasn't clear I have managed to cobble something together but I would like to return it to stock.thanks for your help
Post by v8pete on Mar 1, 2017 20:06:02 GMT
What I did was use use the early throttle return spring set up inc the lever on the shaft and the bracket on the water flange
Post by Warwick on Mar 2, 2017 0:21:06 GMT
V8pete, I'm confused. This is a 2 year old thread. Are you looking for a cable? You didn't actually say anything. You did a man look Warwick : ) That's the only kind I'm capable of doing, Andy. It's a gender thing. Now I see! It's hidden inside the quoted post.
Post by eightofthem (Andy) on Mar 5, 2017 20:39:27 GMT
You did a man look Warwick : ) That's the only kind I'm capable of doing, Andy. It's a gender thing. Now I see! It's hidden inside the quoted post. Haa, I only clocked it because I posted the picture and didn't remember the spring bit.
