Post by norvin on Mar 27, 2015 12:36:26 GMT
I bought this radio from ebay some time ago and I have put the code in but keep pressing all the buttons but it will not take the code. Has anyone an idea what buttons I need to press? it's a 1994 Blaupunkt set and you can see on the flap for the tape it says Rover so it came from a Rover car .The code I have put in is correct.
Post by David on Mar 27, 2015 13:14:22 GMT
Sometimes these systems need to be 'divorced' from the car first? This usually involves a dedicated laptop/software system. Not sure wht Rover did at that time, but hopefully someone may be able to offer better advice.
Post by eightofthem (Andy) on Mar 27, 2015 13:24:08 GMT
Usually the four digit code is entered by the first four buttons, ie, number 1 for the first code number, number 2 for the second code number.......... Then number 5 when when all done. Say your code is 7682, then the first number on the radio face "1" must be pressed 7 times, the second number "2" must be pressed 6 times to enter the next number....... You get the idea. Try that.
Post by norvin on Mar 27, 2015 13:50:48 GMT
Usually the four digit code is entered by the first four buttons, ie, number 1 for the first code number, number 2 for the second code number.......... Then number 5 when when all done. Say your code is 7682, then the first number on the radio face "1" must be pressed 7 times, the second number "2" must be pressed 6 times to enter the next number....... You get the idea. Try that. Thanks yes I put the code in ok but what do I press then. Nothing seems to work.
Post by eightofthem (Andy) on Mar 27, 2015 14:16:56 GMT
On some models like Ford, once the correct code is entered the radio comes on, some models you have to press the next number button. Could be the wrong code, I have a rover cassette player here from my old Tourer, you are welcome to that should yours not work for you.
Post by davewright on Mar 27, 2015 14:22:27 GMT
Press Tuning Up Button " ^ " To Enter
Post by davewright on Mar 27, 2015 14:24:14 GMT
Full instructions are:
Turn Off Stereo Press and Hold " FMT " and Preset " 1 " Switch Radio On - Display Shows " CODE " Press Preset " 1 " and the display will show " 0000 " Press preset " 1 " repeatedly for 1st Digit Press preset " 2 " repeatedly for 2nd Digit Press preset " 3 " repeatedly for 3rd Digit Press preset " 4 " repeatedly for 4th Digit If the correct code number is now shown Press Tuning Up Button " ^ " To Enter
Post by norvin on Mar 27, 2015 15:10:15 GMT
On some models like Ford, once the correct code is entered the radio comes on, some models you have to press the next number button. Could be the wrong code, I have a rover cassette player here from my old Tourer, you are welcome to that should yours not work for you. Thanks that is very kind of you.
Post by norvin on Mar 27, 2015 15:13:57 GMT
Full instructions are: Turn Off Stereo Press and Hold " FMT " and Preset " 1 " Switch Radio On - Display Shows " CODE " Press Preset " 1 " and the display will show " 0000 " Press preset " 1 " repeatedly for 1st Digit Press preset " 2 " repeatedly for 2nd Digit Press preset " 3 " repeatedly for 3rd Digit Press preset " 4 " repeatedly for 4th Digit If the correct code number is now shown Press Tuning Up Button " ^ " To Enter Yes I have done all of that trouble is what ever button I press the set will not except the code. The seller tells me the code he gave me is correct.
Post by davewright on Mar 27, 2015 15:26:17 GMT
Post by norvin on Mar 27, 2015 15:59:12 GMT
Thanks the trouble is I think it is correct as it is on the case of the set twice and one looks like an original label. The cost is £8-99 per code.
Post by Simon H on Mar 27, 2015 21:31:35 GMT
I suspect the radio is not acknowledging the attempt to enter the code. If the code was incorrect and it was 'accepting' the attempt to enter the wrong code it would go into a failsafe mode after a set number of incorrect entries. Typically it would allow 3 attempts and then shut down for a period of time (e.g. 1 hour). Then it would allow 3 more goes and shut down for a much longer period (days, rather than hours) and so on... I believe the same radio is in my dad's 416 Tourer but I won't be able to look in the handbook for the model specific info until Sunday. I will report back in due course.
Post by norvin on Mar 27, 2015 22:04:06 GMT
I suspect the radio is not acknowledging the attempt to enter the code. If the code was incorrect and it was 'accepting' the attempt to enter the wrong code it would go into a failsafe mode after a set number of incorrect entries. Typically it would allow 3 attempts and then shut down for a period of time (e.g. 1 hour). Then it would allow 3 more goes and shut down for a much longer period (days, rather than hours) and so on... I believe the same radio is in my dad's 416 Tourer but I won't be able to look in the handbook for the model specific info until Sunday. I will report back in due course. Thanks Simon I would appreciate that. I am working in the dark without a handbook.
Post by Simon H on Mar 28, 2015 20:13:33 GMT
Sorry Norvin, the radios covered in my dad's 416 handbook are completely different. No point explaining the procedure because the punchline is that the radio accepts the code as soon as the final number is entered...
Post by norvin on Mar 28, 2015 21:16:03 GMT
Sorry Norvin, the radios covered in my dad's 416 handbook are completely different. No point explaining the procedure because the punchline is that the radio accepts the code as soon as the final number is entered... Thank you for taking the trouble of looking it is much appreciated.
