Post by Deleted on Mar 29, 2015 15:33:55 GMT
The wiring diagrams show a three pin flasher unit is fitted to the P5 series including the coupe. (unless this was amended after the date of my manuals). Today when fitting a warning buzzer to the circuit I discovered the wiring is different and what looks like a more modern two terminal small square flasher unit is fitted. I can still use the buzzer OK by fitting a three terminal old fashioned unit and using the third terminal but I'm curious,is (or rather are) the manuals wrong?
Post by johnwp5bcoupe on Mar 29, 2015 17:03:08 GMT
Mine is a 3 pin Kev
Post by Phil Nottingham on Mar 29, 2015 17:33:52 GMT
On Search but later ones with TP coil had a 2 pin. Both types are mechanical and small wiring mods needed to swap or to fit electronic types.
Handbooks only were modified buy still had errors - WSM's were not
Post by lagain on Mar 29, 2015 19:15:41 GMT
Many years ago someone recommended using a Lucas SFB 162 electronic unit as the original can have an erratic flash. The SFB 162 has 3 terminals although if I remember correctly a simple modification has to be made to the connections. I have one on my car and it is excellent
Post by Deleted on Mar 29, 2015 20:29:30 GMT
this is the flasher in my P5 and its a two pin square model. (see pics !)
Post by Phil Nottingham on Mar 29, 2015 21:33:47 GMT
That is the correct one for late 5B's - standard fit on all BLMC models then and Ford used them from the late 1960's. Sold as "no delay" start and louder click
Post by Deleted on Mar 30, 2015 8:17:43 GMT
That is the correct one for late 5B's - standard fit on all BLMC models then and Ford used them from the late 1960's. Sold as "no delay" start and louder click . Yes that's the one fitted to mine so it seems that some manuals and handbooks are wrong. I have fitted a three terminal version and used the third terminal to drive a small buzzer. My winners don't always self cancel and I find it easy to overlook the warning lights. Thanks for the replies.
Post by Phil Nottingham on Mar 30, 2015 17:32:29 GMT
That will work but the warning lights may not or be on the wrong sides
Post by Deleted on Mar 31, 2015 9:05:00 GMT
The warning lights aren't affected and so work fine,the buzzer is a bit loud so I've buried it behind the dash.
