Post by petervdvelde on Mar 4, 2015 20:14:31 GMT
Received my second set of 4 Jensen alloys which i will fit to the daily P5B. This set requires more work as these look shabby and the tyres are shot. After having a better look at the wheels, it shows that these are covered in a poor layer of a clear coat. I took a piece of sanding paper and sanded the clear coat of the left spoke and got to nice aluminum. It will take a fair amount of work to get these nice again but threw Ebay at GBP 180,- for the 4 wheels and GBP 80,- for the courier to ship these from the UK to Holland, i believe its a good deal as these seldom come up for sale. Will still be looking for 2 spare wheels. The car behaves very well and copes well with the winter weather. The chrome seems to cope well with the salt. However the Rostyles and wheelnut show some rustspots. The plan is to get a set of poor Rostyles silver powder coated and use these the next winter and use the Jensen alloys during the other seasons. Regards Peter
Post by petervdvelde on Mar 21, 2015 21:12:56 GMT
Managed to find a 5th Jensen wheel only 30km from where i live. The wheel had some damage on the the edge of the rim so i brought it to a man who weld some aluminum to these spots Removed all paint and clear coat with paint stripper and with sand paper removed most scratches and corrosion marks on the 5 spokes and the rim. The wheels are now ready for polishing. Now waiting for the arrival of the polishing grease. Peter
Post by petervdvelde on Mar 27, 2015 15:18:33 GMT
Polished the first rim and am very happy with the result. This is a much more rewarding job than sanding the rims with sandpaper. and another 4 to go.... Peter
Post by eightofthem (Andy) on Mar 27, 2015 18:00:32 GMT
Very nice Peter.
Post by Steve P5b on Apr 2, 2015 15:09:29 GMT
Polished the first rim and am very happy with the result. This is a much more rewarding job than sanding the rims with sandpaper. and another 4 to go.... Peter Very nice job, what about the other side though ?
Post by David on Apr 2, 2015 15:13:44 GMT
Steve, that's hidden by the tyre
Post by petervdvelde on Apr 13, 2015 18:21:16 GMT
Very nice job, what about the other side though ? Steve, will run out of "elbow grease" so will not polish the other side Have polished the other 3 rims. The spare rim hasn't returned from the welder I also polished the sides of the spokes and the area around the wheel nuts. Normally only the top of the 5 spokes and the outer rim are polished and the sides of the spokes are coated with paint but i believe this would give a too modern look. The non polished area's will be painted black. Peter
bigandy
Post by bigandy on Apr 19, 2015 20:46:41 GMT
Peter what polishing grease do you use ?
Bigandy
Post by petervdvelde on Apr 20, 2015 20:48:56 GMT
Andy, I use 3 different polishing disc's and 3 type's of grease. The first step is the smaller disc, hanging on the hook with the brown grease, then the disc on the right on the shaft with the pink polishing grease and the last step for high gloss is the disc on the left on the shaft with the yellow grease This weekend i picked up the fifth wheel from the welder who welded up 2 damaged area's on the rim edge. With a file i cleaned the weld and did some remaining sanding work and polished the rim. Peter
Post by Steve P5b on Apr 20, 2015 21:02:39 GMT
Looking good.
Post by petervdvelde on May 8, 2015 21:33:00 GMT
Now the polishing was finished it was time to "restore" the other area's as there was a fair amount of corrosion on the rest of the rims. The plan was to get the rims shot blasted with glass pearls and after that a layer of epoxy primer. I have a small blasting cabinet but this is too small for the rims. I put 2 layers of Duc tape over the polished area's to protect this against the shot blasting Today i picked up the rims from the shot blasting company which also put the epoxy primer on. The Duc tape protection against the shot blasting worked very good. Next job is to sand the primed area's with 400 grid. I will bring these to a friend who will put some spray filler on the area's on the front of the rims. Peter
Post by RedP5B on May 31, 2015 6:00:53 GMT
I have a set of Jenson Alloys (in a bad state but if someone can do something with them they are here for price of alley)
Post by Deleted on May 31, 2015 6:41:23 GMT
Hi redp5 have you pictures of the wheels please I would be interested in them
Post by RedP5B on May 31, 2015 6:44:24 GMT
I am aylt work this morning. I will try to get some later and post them.
Sent from my SM-G900F using proboards
Post by Deleted on May 31, 2015 7:00:35 GMT
Cool thank you
Post by RedP5B on May 31, 2015 16:56:09 GMT
Like I said, they aren't great but they arent a priority at the moment. There are other bits I need more Attachments:
Post by Deleted on May 31, 2015 20:04:43 GMT
They are save able with a lot of work. What do you value them at please
Post by RedP5B on Jun 1, 2015 4:44:40 GMT
Well I have just ordered a pair of indicator lenses which cost me £30 so if I could get that back would be good.
Post by Deleted on Jun 1, 2015 18:29:17 GMT
Where are you based mate I will pay that for them
Post by petervdvelde on Jun 1, 2015 21:45:58 GMT
Hello Paul,
You are a brave man if you want to polish the "spokes" and the outer rim as looking at the condition of these wheels , you will find a lot of deep pitting. I would get these beat blasted and painted in silver/black in combination with some filler. Peter
Post by djm16 on Jun 2, 2015 2:55:03 GMT
Are you going to clear coat again?
Post by RedP5B on Jun 2, 2015 12:48:12 GMT
I live in Bexleyheath, but work at Elephant and Castle.
Post by Deleted on Jun 2, 2015 20:18:45 GMT
Hi there. Can you please inbox me a contact number please and I will discuss a money transfer and a courier to collect the wheels from you at a suitable time etc
Post by Deleted on Jun 2, 2015 20:19:44 GMT
Peter. What wheel nuts did you use to fix these wheels to your car please
Post by petervdvelde on Jun 3, 2015 5:52:22 GMT
Paul,
The wheels are not fitted yet. I bought some aluminum nuts from Charlton classic Cars. These are well made and fit well but i have to get used to the fact that these are made from aluminum. SteveP5B had a source where you can buy steel nuts. You could find this using search.
This thread showed up on the Classic Rover Forum. This shows a pair of Jensen wheels which were not so good but look nice after restoration. (http://www.classicroverforum.net/viewtopic.php?f=21&t=20892)
Regards Peter
