Post by Jens Munk on Apr 30, 2015 11:36:37 GMT
Thanks a lot Allan,
Unfortunately Denmark is not Rover-land, so I am still wondering about the surprise.....
So at least I am not the only one with this obnoxious problem. I will work through your nicely prioritized list and see if any clues appear as well as keeping you updated. Tomorrow is a holiday here, so I have a three day weekend ahead.
I asked the questions at the start of the thread relating to engine/drive train to try and narrow down the issues.
Chuck, with all due respect, what you are referring to are drive train issues. Jens has confirmed his vibration is engine speed related as the vibration is present at specific revs with the car in neutral (and also presumably park) and stationary.
It seems that when it comes to vibrations people confuse engine speed and road speed vibration issues. Of course the two can be linked and both can be present. I'm only dealing with engine vibration issues in this post.
I have spoken to many people about this subject, some have even sought me out having spoken to other well known and well respected members of the club who have pointed them in my direction as a result of my (non conclusive) experience of this issue.
I have been through a whole world of pain trying to track down the vibration. The engine has been apart twice and all moving parts balanced by one of the most experienced of Rover V8 engine balancers that does work for all of the Midlands based V8 builders. Everyone is out of ideas. But I haven't given up just yet. However I have had to put things on hold due to life getting in the way.
Of course Jens, your vibration could be caused by different factors than mine. For reference purposes mine is around the 1700 to 2200 revs. A number of the people I have spoken to with the same issue seem to have the problem around the same revs.
Now that you have established it’s the engine not the drivetrain, here's my suggestions to narrow the field.
Take the two drive belts off (Power steering and fan belts) or at least slacken them so they are loose enough that the auxilliary pulleys don't turn and run the engine briefly and through the rev range. Is the vibration still there? This will also eliminate the fan being out of balance.
Next, assuming vibration is still present, inspect the engine mounts and the damper. Place a little strain on them using a jack to check for any splits or wear (I changed mine as I had a new set knocking about) and take the load off them, loosen the bolts, lower the engine and re-seat it in case it wasn't fully resting in its mounts. Then retighten the nuts and test. Cured?
If not look at the gearbox mount. Is it split or damaged. is it secure? If so remedy/replace/tighten.
Front pulley is an awkward one. I tried an alternative pulley and also had mine checked for balance (it was fine). Its awkward because its difficult to remove without taking the radiator off, the bolt is tight and locking the engine up is difficult if its not still connected to the drivetrain (ask me how I know), and it needs a good puller to persuade it off the crakshaft nose (don't lose the woodruff key).
Torque converter: Remove the half moon plate and rotate the flexplate so you can undo and remove the four bolts and move the TC back from the flexplate. Then run the engine again BRIEFLY and test for the vibration.
Still there? Remove the gearbox and run the engine without it connected and test for vibration?
Still there? Remove engine, strip and have all moving parts balanced.
Still there? Find another solution and let me know...
This thread has set me thinking again. If Jens had no vibration and all he did was rebuild the carbs could this be to do with how the vacuum builds up and affects the lift of the pistons in the dash pots.
Although the vibration in mine feels like a mechanical issue of something out of balance I suppose a partial misfire could cause the same feeling.
I also know Jens had to change one of the subframe/engine isolators (I sent him an old one of mine as he couldn't get one in Denmark - You still owe me a surprise Jens ;-)). However, I changed the whole subframe and put in all new isolators and the vibration existed before that so I know it’s not related.
N.B. As in previous threads on this topic I am trying to assist by giving the benefit of the time amd money I have spent in trying to resolve this issue to save others time and money and am happy to discuss it. If anyone wants an argument or to make personal remarks please take it elsewhere.
Oh dear. Here we go again.
