Post by radrick on Jul 6, 2015 15:51:47 GMT
I can undo the first bolts (the ones where you can see the round things they screw into in the boot) but I can neither see or feel the furthest forward one, I can see the round thing from inside the cabin but dont want to have to drill it...
Post by petervdvelde on Jul 6, 2015 21:13:34 GMT
The 3 bolts closest to the rear door have to be loosened from the outside. The round things you mention are nuts welded onto the "boot side"
Post by radrick on Jul 7, 2015 14:57:49 GMT
I already said I can undo the first ones, its the last bolt that screws into the cabin that I cant find
Post by guidedog on Jul 7, 2015 15:07:05 GMT
It's there go under the wing right in the corner. It will feel like a lump because of the muck that has collected around it.It doesn't go into the cabin
Post by Deleted on Jul 7, 2015 15:14:51 GMT
I already said I can undo the first ones, its the last bolt that screws into the cabin that I cant find As this area is one of the worst rust areas on the car, are you sure there is actually anything to see? What is the general state of the area?
Post by Phil Nottingham on Jul 7, 2015 18:06:43 GMT
Mole grips - otherwise cut away top of wing over bolt!
