Guus
Post by Guus on Aug 24, 2015 15:47:20 GMT
Hi, I am in the process of replacing the wiring of the Rover. I stripped the old harness and at the moment I am putting in the new one. The main harness runs under the bonnet. In order to get it nicely under the bonnet-hinge, I want to release one side of the hinge so I can lift it and put the harness underneath. Unfortunately, the bolt located in the attached picture, is rusted to its counter-screw... Does anybody know how I can access this counter-screw? Thnx Guus
Post by johnwp5bcoupe on Aug 24, 2015 15:58:17 GMT
Hi, I am in the process of replacing the wiring of the Rover. I stripped the old harness and at the moment I am putting in the new one. The main harness runs under the bonnet. In order to get it nicely under the bonnet-hinge, I want to release one side of the hinge so I can lift it and put the harness underneath. Unfortunately, the bolt located in the attached picture, is rusted to its counter-screw... Does anybody know how I can access this counter-screw? Thnx Guus View AttachmentThat's a captivated nut Guus so the nut is welded to the bulkhead If it doesn't undo and snaps off it's a case of drilling out the old bolt and re-tapping the thread or drilling it as best you can to the minimum thread dia and collapsing what is left of the old bolt
Guus
Post by Guus on Aug 25, 2015 5:43:06 GMT
Thanks John! I was kind of afraid of that...
