Post by wozzer on Apr 10, 2016 17:50:34 GMT
The top section also needed attention so this was cut out as well. A repair section was fabricated, this is a quick shot just after being prepared for welding. And this is after being welded, dressed and painted. The outer box section can now be obtained but i will wait to get this in my hands before i decide how far i need to cut back the remaining rust pitting. More soon Woz
Post by wozzer on Apr 10, 2016 20:28:52 GMT
Seems a pity not to incorporate the jacking mounting in the rebuilt section and its absence will be obvious. Maybe to some, no point paying out and installing things that will never be used i wont miss them
Post by wozzer on Apr 27, 2016 22:31:01 GMT
Spent the last few visits starting to repair the d post area, this side had quite a bit more rust lower down in the splash panel and around the seat belt mount. Made and welded in this section Next was to repair this small hole in the chassis before the new splash panel is installed.
Post by wozzer on Apr 27, 2016 22:39:29 GMT
_ This is a quick shot with the d post removed. This picture shows the inside of the wheel well after the patches were dressed back and primed. And this is a shot with the splash panel welded in, primed and ready for bodyworking. Next will be to repair the catch box area and then to work along the inner rear wing. More soon Woz
Post by wozzer on May 2, 2016 9:44:33 GMT
Last bits of rust cut out on the near side inner wing and the box section removed. Woz
Post by wozzer on May 2, 2016 16:54:44 GMT
Spent the day today finishing off the inner front wing. Welded in the new full length box section. Then prepared and fitted the new full splash panel. Coated these repairs ready for the final body working. More soon Woz
Post by wozzer on May 5, 2016 17:28:00 GMT
Spent a couple of hours making this panel which sits just behind the d post inside the car right above the wheel well. Im pleased with the way it turned out, pretty nice. Woz
Post by wozzer on May 14, 2016 7:23:31 GMT
Spent a few hours yesterday cutting and fitting the new crossmember end repair, i still have a small amount of weld to dress back but overall its done. Onto the d post again today. Woz.
Post by wozzer on May 20, 2016 6:40:12 GMT
Made up this panel with my new stretcher to repair a small amount of rust in the rear wheel well just behind the d post. Repaired this section just to the right of the rear seat base between the d post and sill Also spent a bit of time preparing the new catch panel. Made up the extention as per the original and seam welded this to the panel ( small shaped piece on the right ). Then i removed the old captive nut plate from the old catch panel and transfered this to the new, plug welding this into position. More soon Woz
Post by wozzer on May 21, 2016 17:39:32 GMT
Spent the last couple of days installing the new catch panel and d post. I have taken time to blend the two together so minimal bodyworking is required. Im not sure whether i am going to lead these repairs as per original, i will decide at a later date. Here is a quick picture of the inner d post closing panel dressed back and coated ready for body work. I wanted to check the fit of the replacement rear wings i got from ebay, these are original and in perfect order. This is what it looks like , chuffed to bits. Woz.
Post by petervdvelde on May 22, 2016 7:07:57 GMT
Very nice work and impressie progress!. I did the leading of the area near the catch panel and the d-post and i understand your thoughts as acces with a file is very difficult and the lead easily drips of . I can remember i produced a symphony of cursus leading that area. Rear wing looks like it fits well but final judgement can be doen with the door next to it.
Post by enigmas on May 22, 2016 22:33:03 GMT
Nice progress Wozzer...it's lookin' good. I can remember i produced a symphony of cursus leading that area. Peter Very poetic Peter...I never heard 'frustration' expressed that way before!
Post by wozzer on May 23, 2016 18:54:46 GMT
Very nice work and impressie progress!. I did the leading of the area near the catch panel and the d-post and i understand your thoughts as acces with a file is very difficult and the lead easily drips of . I can remember i produced a symphony of cursus leading that area. Thanks peter. I know what you mean, when youve almost got there , just a little more heat..... and then your scraping it off the floor. doh! Still practice makes perfect. Woz
Post by wozzer on May 23, 2016 19:00:18 GMT
Nice progress Wozzer...it's lookin' good. Many thanks enigmas
Post by Roy of the Rovers on May 24, 2016 13:55:16 GMT
Agreed, really good 'home' restoration. That's a lot of metal you have chopped out and replaced there. Nice work.. Must pop over sometime when you are there
Post by wozzer on May 26, 2016 6:26:59 GMT
Agreed, really good 'home' restoration. That's a lot of metal you have chopped out and replaced there. Nice work.. Must pop over sometime when you are there Cheers Roy. I will be over the farm this weekend. probably saturday but there is no fixed times. Woz
Post by wozzer on May 26, 2016 23:39:04 GMT
Had a bit of time over the last couple of days to finish off the repairs over the wheel well. Cut out and scratch built this panel complete with the new captive nuts, plug welding this in place around its perimeter. On the whole this is finished apart from some weld dressing and final bodyworking. Woz.
Post by wozzer on May 30, 2016 17:05:19 GMT
Managed to spend a few hours this weekend finishing off the catch panel. Tacked in the final small closing fillets and strengthening pieces. Then finished this off with the final closing panel, cleaned up the welds and primed ready for finishing. More soon Woz.
Post by wozzer on Jun 2, 2016 16:51:36 GMT
Wanted to repair this small section of rust in the rear inner wing top. This pic shows the rust and all the spot welds in the top flange drilled out. I fabricated this small repair section Here it is welded in place ready for final finishing. Next on to the lower edge rust repair and boot corner, getting close to the rear now?
Post by petervdvelde on Jun 2, 2016 22:10:42 GMT
nice repairs! I replaced the entire panel which took a lot of time to get it right. I also made the recessed area's in the panel. Its nice to have a entire fresh panel but it took a fair amount of time and replacing the rusted area's would have saved a lot of time
Keep up the good work as you must be close to the end now
Post by wozzer on Jun 3, 2016 20:15:50 GMT
Many thanks for the kind words peter. Getting close to the end of the structural repairs now, probably 4 weeks or so then onto the more exciting stuff. Woz
Post by wozzer on Jun 12, 2016 19:42:52 GMT
Spent the last few days cutting out the rot in the near side rear quarter. Removed the rusty portion of chassis rail and boot floor. Then i cut out the rust on the bottom of the rear panel. Made up a new repair section Then i cut out the remaining rust in the wheel well and made a repair section for this also.
Post by wozzer on Jun 12, 2016 19:51:41 GMT
This is the wheel well repair welded in place And the rear panel lower repair And a quick shot of inside the boot showing the new boot corner in place and the rust hole in the inner torneau panel ready to be cut and replaced. Next will be the new chassis rail section and onto the rear panel repairs. Also just ordered the new suspension parts from the usa so that will bring a welcome releif from rust repairs. More soon Woz
Post by wozzer on Jun 17, 2016 17:23:10 GMT
Spent a bit of time this week fabricating the new chassis repair section for the near side. Welded this into place and coated. Waiting now for the final repair sections for the rear so i can then fabricate the inner rear valance. Woz
Post by Roy of the Rovers on Jun 20, 2016 12:01:31 GMT
I went to visit Wozzer at the weekend hidden away in deepest sussex countryside. He's doing a good job rescuing another P5 that would definitely have ended up going around the track. Nice guy too
