Post by wozzer on Nov 15, 2016 19:51:32 GMT
Back on to the front of the car to carry out the last repairs on the inner wing. Here are a couple of pics of the damage and the started repairs. Next steps will be the installation of the new box section and the upper splash apron
Post by wozzer on Nov 19, 2016 16:42:56 GMT
Last part of the puzzle was to replace the box section then to make the top section of the splash apron. Here is the finished item
Post by wozzer on Dec 27, 2016 17:43:09 GMT
Starting to finish off all the repairs getting down to the nitty gritty now
Post by wozzer on Dec 28, 2016 19:08:30 GMT
Aerial hole done today
Post by wozzer on Jan 7, 2017 18:24:41 GMT
A few more pics of progress, seam sealer applied to all the seams ready for underseal. Moved onto filling the rear panel to straighten a few warping issues, last pic is ready for primer.
Post by wozzer on Jan 14, 2017 17:04:24 GMT
Repairs complete, undersealed and looking good
Post by wozzer on Jan 14, 2018 20:00:02 GMT
I have Been trying very hard not to over restore the coupe but to try and keep as much of the original paintwork as possible . The engine bay has been looking very worse for wear, especially on the drivers side, so this has been my focus for several weeks along with the painting of the front floor repairs. All the repairs have now been filled and etch primed ready for primer. The engine bay will be painted in original Bordeaux red, the floors and inner wing panels will be painted with Schutz ready for the chassis to be refitted.
Post by Roy of the Rovers on Jan 16, 2018 12:32:32 GMT
Looking fantastic Woz, I love the clean look of primer . Seeing the condition now I really can't believe you found this car in a field!
Post by wozzer on Jan 20, 2018 18:34:24 GMT
Spent a few hours at the lockup getting the inner wings in colour. Tomorrow's job will be to Schultz the floor repairs and the inner wings the I can finally install the chassis and get the suspension back in. W.
Post by Ken Nelson on Jan 20, 2018 22:04:09 GMT
Very nice patch work Wozzer. Interestingly I note that in your Dec 2016 posting you showed filling in of a hole used for an aerial. I am planning to do just the opposite because I need to fit an aerial to my car for the radio. I can't tell if that hole was near the front windscreen or the rear one. Here in the US it is not at all common to fit aerial to the roof as they do in England. Does anyone have suggestions on the best place to fit an aerial on the body of the car, or other suggestions?
Post by wozzer on Jan 21, 2018 10:38:38 GMT
Very nice patch work Wozzer. Interestingly I note that in your Dec 2016 posting you showed filling in of a hole used for an aerial. I am planning to do just the opposite because I need to fit an aerial to my car for the radio. I can't tell if that hole was near the front windscreen or the rear one. Here in the US it is not at all common to fit aerial to the roof as they do in England. Does anyone have suggestions on the best place to fit an aerial on the body of the car, or other suggestions? Cheers Ken Aerials are usually fitted so they are fairly easy to hook up, I must admit I prefer them on the roof because I think they look better. The one I took off of my rover was on the rear scuttle just behind the rear screen. Good luck W.
Post by Phil Nottingham on Jan 21, 2018 12:08:50 GMT
I think the reception is better on the roof, they are much easier to fit and far less susceptible to vandalism.
The only downside is that if they are angled up too much they can foul car park barriers especially in the of the low height multi stories. Our sometimes catches on our garage doors reversing out if I have moved it up slightly washing it.
My dad's old 1951 Standard Vanguard had an internal knob on the screen header rail that swivelled down in line with the central windscreen divider - neat!
There would, however, be room to fit an electric automatic one behind the front wing splash panel but far more trouble as it involves at least undoing the bottom wing mounting bolts if they had not rusted out
Post by Ken Nelson on Jan 21, 2018 17:18:19 GMT
Thanks Phil and Wozzer. I'll have to do some more investigating from under the front fender. I think that an older car here in the States would look more "proper" with a fender mounted aerial than on the roof. Likewise the right front fender would be the standard mounting location.
Post by wozzer on Jan 21, 2018 18:36:38 GMT
Another fairly productive day, I managed to get the front floor and sill repairs coated in stone chip. Then I managed to tape and stone chip both inner wings which now means I can reinstall the chassis. Once done all the new front suspension can be reinstalled for the last time which means I'm getting somewhere.
Post by wozzer on Jan 31, 2018 17:50:12 GMT
Final bit of coating done now ready for chassis install.
Post by wozzer on Feb 2, 2018 19:55:18 GMT
I seem to be Getting somewhere now. Chassis ready to be installed with it's newly inspected and painted body mounts. Should have this installed along with the front suspension tomorrow.
Post by wozzer on Feb 4, 2018 18:32:25 GMT
Chassis all bolted in looking sweet
Post by wozzer on Jun 18, 2019 19:58:06 GMT
It's been quite a while since my last post but I have not been idle. I will update this thread with a few pictures rather than words to bring it up to date...please feel free to chip in with any comments
