Post by wozzer on Jan 21, 2017 16:50:00 GMT
Post by guidedog on Jan 22, 2017 10:00:58 GMT
Your car wouldn't like my speed bumps I have in my road.
Post by wozzer on Jan 22, 2017 17:17:41 GMT
Dont worry guidedog with the airbags i will be able to get over any speed humps
Post by Roy of the Rovers on Jan 22, 2017 18:11:22 GMT
This is the trial run for Wozza to do mine ... isn't that right Woz ?!
Post by wozzer on Jan 22, 2017 18:47:59 GMT
This is the trial run for Wozza to do mine ... isn't that right Woz ?! Be a shame to do this to yours roy.....now that old convertible youve got in the garage is another story😉
Post by Roy of the Rovers on Jan 22, 2017 18:57:44 GMT
OK you persuaded me....
Post by bissmire on Jan 30, 2017 14:22:44 GMT
looking good Wozza.
Post by wozzer on Jan 31, 2017 17:31:50 GMT
Thanks james
Post by wozzer on Apr 16, 2017 8:48:47 GMT
Not updated for a while due to a real nuts start to the year. Been waiting for the wheels to arrive which were ordered in january and here they are They may devide opinion but they will definately make a statement. Now i have these i can get on with the front suspension when funds allow ! Back to getting the body repairs ready for paint More soon Woz
Post by enigmas on Apr 16, 2017 12:28:57 GMT
I can see that you're serious about your new wheels Woz if you've got them displayed in the lounge room...either that or it's a very pristine garage! As an aside if you remove the hub cap and add a spinner it could almost be a D type Jag wheel.
Post by wozzer on Apr 16, 2017 14:21:48 GMT
Exactly enigmas, they are a 3 piece billet copy of the D type wheel, i can indeed get a spinner to fit these wheels and i might so i will have two different looks
Post by wozzer on Jun 10, 2017 16:26:08 GMT
A couple of pics with the new wheels on whilst waiting for the front air shocks to turn up! Hopefully more quite soon
Post by wozzer on Jun 15, 2017 21:14:32 GMT
Front slam air front shocks have arrived. Just need to take measurments now and send these to wayne who will then create and fabricate the new front clip which i will then weld into the car. More soon
Post by wozzer on Jul 13, 2017 9:58:17 GMT
Post by wozzer on Jul 13, 2017 9:59:51 GMT
More soon
Post by wozzer on Aug 7, 2017 19:11:12 GMT
All the components just back from the powder coaters all ready for assembly. Next job is to remove the engine and old front suspension and steering. More soon
Post by wozzer on Aug 11, 2017 16:56:55 GMT
Ok here we go strip down of the front end has started with removing the rad and surround so we can remove the engine. I've decided it will be a good idea to remove the subframe as well so i will make plans for this also.
Post by wozzer on Aug 19, 2017 14:23:04 GMT
Yay ..Engine out ! Steering box, idler and shafts removed.
Post by enigmas on Aug 20, 2017 6:40:58 GMT
Hi Wozzer...what are you going to do about the subframe mounts...if they're OEM they're probably rotted and decayed?
Post by wozzer on Aug 20, 2017 8:52:53 GMT
Hi Wozzer...what are you going to do about the subframe mounts...if they're OEM they're probably rotted and decayed? Hello enigmas I will have to wait and see when i remove the subframe but i should imagine they are originals. When i removed the rear mounts when i repaired the crossmember ends these were in very good order but then they never had all the contaminents of the engine bay to contend with. So far all the bolts have undone incredably easily so im hoping for a very smooth removal of the frame. Woz
Post by wozzer on Aug 26, 2017 16:43:50 GMT
Subframe removed and stripped and looking in great shape. Crossmember to go on next right after a good bit of cleaning
Post by petervdvelde on Aug 26, 2017 18:46:01 GMT
Great job you are doing! now the subframe is out, i would drill a few holes in the rear part where the torsion spring go threw the subframe as water can't leak away there. Keep up the good work and keep posting!
Post by wozzer on Aug 31, 2017 17:36:37 GMT
Great job you are doing! now the subframe is out, i would drill a few holes in the rear part where the torsion spring go threw the subframe as water can't leak away there. Keep up the good work and keep posting! Peter Thanks for the tip peter i will look into the drain holes once ive got my new crossmember fitted W.
Post by wozzer on Sept 8, 2017 14:50:26 GMT
My new wilwood brake kit arrived today A whopping 310mm vented disc's with four pot calipers should help pull the old girl to a fairly rapid halt. I'm starting the installation of the crossmember so should have some decent pics soon. Woz
Post by wozzer on Sept 11, 2017 10:03:43 GMT
New crossmember now in place, just got to fabricate and replace the strengthening gussets between the engine tubes and the original crossmember. Wishbones assembled with new bushes and attatched complete with stub axles to see how it looks. More soon Woz
