Post by enigmas on Sept 28, 2016 10:09:32 GMT
Post by djm16 on Sept 28, 2016 22:58:12 GMT
Very nice, bit I didn't see a place to put the "Start-ya-bastard". (Eazistart for the Southern Hemisphere).
Post by enigmas on Sept 29, 2016 7:13:26 GMT
If you look carfully you'll see a faint yellow colour underneath the plastic bag...that's a small aerosol of CRC Aerostart. Fortunately the engine is an easy starter (even with 11:1 compression, hot or cold) as it's fitted with a gear reduction starter motor from a Range Rover and it spins it over like a little 4 banger.
The only time I need to use the aerostart is on club runs, usually over nighters during cold winter morning starts on my friends' cars with B series engines. To be fair though, they're usually well out of tune!
Post by enigmas on Sept 30, 2016 7:55:04 GMT
Here's the cover/storage box virtually finished and only requiring an upholstered material cover to match the battery cover. The end plate has also been fitted and is readily removable if the slave cyl within requires maintenance/bleeding.
