Post by enigmas on Oct 20, 2016 13:49:17 GMT
Ok, I know it sounds like an obvious question, but what are the sizes of the 2 main instruments (Speedo & Tacho) of a P5 coupe? Not just the face size which is obvious but the body size and the hole it goes into. I'd rather not go through the exercise of removing the instrument panel if someone on the Board has access to these details.
Post by johnwp5bcoupe on Oct 20, 2016 15:06:56 GMT
Hi vince the casing front without bezel is the same on all later P5 and P5b if that helps
Post by eightofthem (Andy) on Oct 20, 2016 17:32:46 GMT
I have an empty binnacle in the attic, I will measure it when I get home from school
Post by johnwp5bcoupe on Oct 20, 2016 18:51:46 GMT
The speedometers are the same Dia!
Post by eightofthem (Andy) on Oct 20, 2016 19:03:34 GMT
I make it 112 mm for both openings ( binnacle ) that is, widest points.
Post by enigmas on Oct 20, 2016 21:34:24 GMT
Thanks John and Andy.
