keith
Post by keith on Apr 25, 2006 7:33:02 GMT
My passenger dook lock has started acting up. It doesn't always latch when the door is closed so I have to make sure it is locked before driving off.
The door is fitted correctly so I think that the lock itself must be on the way out. If I managed to secure a replacement (I'm going to try David Green) will it be easy to fit or are there hidden traps I should be aware of?
Cheers, Keith
Post by Phil Nottingham on Apr 25, 2006 17:21:19 GMT
Try Search - but advise as Coupe or Saloon as both totally different
keith
Post by keith on May 28, 2006 20:34:33 GMT
Replaced the door lock today but have one small problem. The lever that connects the lock to the interior door handle was held in place by a (not sure of the proper name) washer that pushes onto the thin rod at the end of the lever. It came off OK put I'm blowed if I can get the B****r back on. Is there a trick to it or can they be used only once? Is there any alternative way of fixing it?
Many thanks, Keith
Post by Phil Nottingham on May 28, 2006 21:14:57 GMT
Strong finger tips! They can be used more than once if they are not bent - then they will just fall off again
Alternatively try some fairly stiff nylon or copper tube of a bore large enough for the rod to go into without too much slack and some grease to hold everything together - this works but its the access that is awkward
