Post by ozriderp5 on May 21, 2017 3:40:12 GMT
Hi All Found this...added a couple of pics for reference. Posted by Harvey check the fluid level as follows: With the transmission at normal working temperature, the engine idling, and the car on level ground, run through the entire selector range allowing a few seconds in each position to allow it to engage, starting and finishing in PARK, then, with the engine still running walk round remove and wipe clean the dipstick and re-insert to take a level. You will have time for a few quick dips to try and get an accurate level. If you add fluid repeat the whole procedure before taking another level. Use only ATF-G or fluid that meets Ford spec. M2C-33G. DON'T use any of the DEXRON type fluids. A small amount of white blackboard chalk rubbed on the bottom of the dipstick, and then wiped off, dries it and makes seeing the level easier. NB. With the MK1 do all of the above but when checking put the car in 'Low'NB. With the MK1 check the level with the engine running and the transmission in 'Low'.
