Guus
Post by Guus on Jun 10, 2006 10:57:41 GMT
I spent ages removing the old paint from my P5b... Finally I got it all clean, I used extra rough sanding paper on the last turn to create a good basis for the epoxy. Then I used degreaser from hammerite for a clean and then applied three layers of epoxy. It looked good! But when sanding down the plaster it came off without any trouble!!! What did I do wrong and what do you use as grounding (I'm afraid I can can get all the epoxy off again...)
Thanks in advance!
Best regards, Guus
Post by Phil Nottingham on Jun 10, 2006 11:16:18 GMT
Expoxy filler will normally stick like glue to any non-gresay steel soothe or rough and even rusty. The hammerite degreaser must have left a residue?
