Post by neil55 on Jun 5, 2017 6:46:55 GMT
hello all, on my automatic gear selector, the black bit on the end which attaches the knob seems to of disintergrated. could anyone point me in the right direction to source a new one ? thankyou neil
Post by harvey on Jun 5, 2017 14:14:12 GMT
Post by lagain on Jun 5, 2017 19:39:49 GMT
It is a piece of cut down hose - I bought one And, it was not even cut straight !
Post by neil55 on Jun 5, 2017 20:19:52 GMT
thankyou for the valid info, so is it a case of 1/cutting a piece of hose and pushing it on tightly over the threaded end of the lever and then 2/ push the black knob on to the hose, if so would i glue the bits or just rely on push fit ?
Post by harvey on Jun 5, 2017 20:32:42 GMT
Put the rubber in the knob, and then screw the knob on so that the lever cuts a thread in the rubber.
Post by Warwick on Jun 6, 2017 2:24:01 GMT
It is a piece of cut down hose - I bought one And, it was not even cut straight ! Not just any old hose however. It's clearly reinforced hose!
Post by neil55 on Jun 6, 2017 9:13:37 GMT
hey!!! thanks for the feedback, found a piece of small heater hose and bingo !!! it works , thankyou all,.
Post by Deleted on Jun 6, 2017 10:52:11 GMT
And presumably saved you £9..30p. !
Post by paulbailey on Feb 6, 2018 15:36:45 GMT
Does anyone know when they changed the knob from round to the later shaped one?
Post by harvey on Feb 6, 2018 17:30:17 GMT
Does anyone know when they changed the knob from round to the later shaped one? It was pretty early on, and was definitely before the selector pattern changed.
Post by Phil Nottingham on Feb 6, 2018 18:45:26 GMT
1969 models ie Sept 68 on - also had plastic interior mirror frame/backing in place of the chromed metal one
