Allan NZ P5b
1971 p5b Auckland New Zealand
Post by Allan NZ P5b on Jul 5, 2017 8:02:03 GMT
1971 p5b saloon fitted with coupe gauges 10 or more years ago by me. Just last week on last outing, noticed temperature suddenly fully in the red. I watch it carefully. Stopped car and checked temperature fine, car fitted with a temperature sensor for electric fan and fan had not cut in, checked with temp gun and only normal temperature. When going to restart car after goes straight to full right ( HOT) ENGINE NOT STARTED. If I disconnect lead goes back to cold. the suggestions are
1 bad earth? not sure what this means engine earth, battery earth as all other electrics seem good from wiring diagram appears to earth though sensor body 2 bad sensor?
I can do more experimenting by earthing sensor wire and seeing what happens or is there an earth inside the gauge pod i cant remember?
Fuel gauge reads accurately ( well as accurately as always)
bit on so would like direction so as to solve quickly
Thanks as always in advance
Post by johnwp5bcoupe on Jul 5, 2017 8:21:25 GMT
Hi Alan if you have 10v? from the regulator and the petrol gauge is ok it sound like your temperature sensor is faulty as basically the circuit is a volt meter. Good luck
Allan NZ P5b
Post by Allan NZ P5b on Jul 10, 2017 6:48:00 GMT
Thanks John. yes had already checked regulator as had an issue with it a few years ago and replaced. Bought a new Tridon sensor TTS029 2 minute job thank you. I knew car was not actually overheating as fan was not cutting in, but still it was disconcerting.
