Post by cronklover on Jul 10, 2017 7:14:57 GMT
my side lights have all of a sudden refused to go out . have to pull the fuse for panel and parking and side lights to get them off ?
any vehicle electricians advise please .
Post by johnwp5bcoupe on Jul 10, 2017 7:56:38 GMT
Does the park position do anything? both lights on? the only item if all is as it should be is the switch!
Post by cronklover on Jul 11, 2017 8:31:35 GMT
had the switch tested ,all ok ? what wires should be connected to switch , maybe one has come off in dash ?anybody know please .
Post by johnwp5bcoupe on Jul 11, 2017 10:09:47 GMT
If you haven't moved any wiring what you describe doesn't make sense if you have a permanent feed to the side lights this can only be done by the switch being faulty OR someone has wired it up incorrectly a wire falling off is not an option!!
Pin1 Fuse 38 Pin 2 Jumps to pin 8 then Ammeter Pin 4 to fuse 29 and headlamp switch Pins 3/5/6/7 switched positions
Have you got a WS manual?
Post by cronklover on Jul 11, 2017 15:51:31 GMT
yes John , have manual . should i do some shuffling with the wiring connections , or will this burn out wiring or pop fuses /I got mot and when i got home saw lights on and they would not turn off .
thanks for your advise .
Post by johnwp5bcoupe on Jul 11, 2017 16:51:19 GMT
The switch connectors are numbered on the back.
Pin 1 is red and brown, Pin 8 is brown and white, Pin 4 is red
Post by cronklover on Jul 12, 2017 11:45:13 GMT
thanks ,will check .
Post by djm16 on Jul 13, 2017 1:21:11 GMT
Is this the type of switch where middle is off, R is all lights and L is parking lights only?
Post by johnwp5bcoupe on Jul 13, 2017 8:27:29 GMT
Yep it should be center off I did ask what happens in the park position? but??
