Post by johnwp5bcoupe on Jul 17, 2006 11:07:33 GMT
Yet another dilema I have seen two origional Coupes one with the roof coach lines 1/2" from the gutter line and the other was 1" is this because Bill did one and Fred did the other? those of you with Coupes if you wouldn't mind having a measure for me please!
Post by David on Jul 17, 2006 13:09:09 GMT
Post by johnwp5bcoupe on Jul 17, 2006 14:40:03 GMT
Thanks David
Post by dorsetflyer on Jul 17, 2006 15:07:40 GMT
Post by johnwp5bcoupe on Jul 17, 2006 21:03:14 GMT
Thanks to you as well John.
Post by johnwp5bcoupe on Jul 19, 2006 17:31:08 GMT
I measure the width of the roof lines as 5/32 is that about right (4mm) ?
bigandy
Post by bigandy on Jul 19, 2006 17:48:46 GMT
great stuff- that was next on my list, if i ever get my car back big andy
Post by johnwp5bcoupe on Jul 20, 2006 7:28:08 GMT
Where are the wise ones I just need conformation before I get my brush out I measured the template on the 1995 article but we all know what can happen when you download and print things alter in size.
Post by David on Jul 20, 2006 9:17:11 GMT
John
Line weights/distances vary from car to car, so as long as you use the template as a guide, you should be OK - the original article was A5 in size, not A4. Just print out the sheet and cut along the line weights so they are on the edge of the sheet - ths will gve you greater accuracy.
The original lines were applied freehand - hence no exact measurements HTH
Post by johnwp5bcoupe on Jul 20, 2006 10:14:00 GMT
OK David thanks I will go for 5/32" line A and line B measure "almost" the same on the sheet line B being a cats whisker narrower plus you get a blurred edge on the print.
Post by dorsetflyer on Jul 22, 2006 15:29:20 GMT
I've just checked on my spare wings, and the coach lines are in fact 1/8" wide, and they are original. I have also checked on my saloon sitting outside and again these are original, and they too are 1/8" wide. If you go too wide it is very noticeable.
Post by Phil Nottingham on Jul 22, 2006 17:28:45 GMT
I agree - they are meant to be thin as these are easier to hand paint as they were originally
Post by johnwp5bcoupe on Jul 23, 2006 6:47:54 GMT
Thanks Phil and John just a well I waited that is why I queried measuring the lines on the 1995 P5 Owners Club article they were wider, I hope you mean hand paint with a bit of help from line tape Phil! my hand is not steady enough! any brave guys out there who would do it freehand???
Post by Phil Nottingham on Jul 23, 2006 7:10:13 GMT
They were hand painted in the factory without any guides - there is a special tool that can be had from Frosts etc. This works similar to a ball point pen - you can also buy magnetic guides
Post by glennr on Jul 23, 2006 7:22:08 GMT
I had mine done last week. He used the books as a guide and I gave him the measurements from the Duchess. I think the coach lines were 5mm thick and the measurement from the inside edge of the roof gutter/roof (using at thin plastic ruler) was 15-16mm. Anyway they have been hand painted and it looks great to me. ;D
Post by PatMcCoy on Jul 23, 2006 7:37:11 GMT
Post by Andy - SE London on Jul 23, 2006 8:36:54 GMT
Post by johnwp5bcoupe on Jul 23, 2006 10:45:43 GMT
I am getting more and more confused I think I will stick to 1/8"for the line weight! the measurement from the rain channelling to the base of the coachline in the article is 30mm does that sound right to those who have an origional roof!
Post by glennr on Jul 24, 2006 17:17:41 GMT
Post by johnwp5bcoupe on Jul 24, 2006 17:28:31 GMT
The definitive answer ;D Dave Green has a barn found Coupe from the bottom of the rain channel to the bottom of the line is 28mm and the line is 4mm in width I will follow the November 1995 Club Mag for all the other dimensions.
bigandy
Post by bigandy on Jul 24, 2006 17:41:07 GMT
yes please big andy
Post by johnwp5bcoupe on Jul 24, 2006 21:32:05 GMT
Looking GOOD Glenn wish mine was ready for the MOT good luck!
Post by lagain on Jul 30, 2006 21:09:49 GMT
This fine weather I do not look at the forum very often, so have just seen this thread.
The coachline on the roof is 5/32" thick. At tne front it is 22mm above the rain channel but by the rear quarter light it is 24mm.
As they were done freehand they will vary.
If I was clever I would take photos and put them on the site, but I am not so I can't !
If you come to the national you can have a look.
I have heard of a tool for doing them which apparantly is very good. Without a tool I would mask up carefully and then spray, using only sufficient paint to get a solid colour to reduce the line left after removal of the tape which hopefully could then be lost with careful polishing with T cut.
Post by Deleted on Jul 31, 2006 9:28:18 GMT
I suppose there are Signwriters who could do the coach line free-hand Must be some in the Yellow Pages. Adrian
Post by Kev on Jul 31, 2006 14:22:03 GMT
I used to be a signwriter but not being in the game for a long while my hands a little shakey, we used to get commisioned to re do the lines on rollers etc, its a skilled job and we used to charge a £100 a side including the hub caps. Big Kev.
