Post by johnwp5bcoupe on Sept 17, 2017 17:34:00 GMT
Can any of the electrical guys suggest the correct rating for the battery earth cable. This is the short section from the negative terminal to the floor.I'm going to replace the existing strap. I've done a bit of research but could do with some confirmation. Thanks in advance. 260amp should be more than man enough Richard such a short length you would get away with 130 amp BRAIDED CABLE
