Post by redsunbeam on Aug 5, 2006 11:44:03 GMT
Between the wooden window frame and the wood panel beneth it there is a black vinyl panel. should these have foam behind the vinyl so they appear padded? All the ones i've seen are baggy like mine. Do they need restuffing or just the vinyl tightening?
Post by Deleted on Aug 5, 2006 12:57:24 GMT
The foam behind degrades into a sticky mess - they should be well padded
Post by Multi-Tech on Aug 5, 2006 22:13:38 GMT
Mines done the same but i have just started to renew the form and will replace the vinyl as I'm going to retrim the the whole car in the winter. Ive also got to do the carpet as it has be change in the past and isn't the right finish. If you are going to the national come over and ill show you the doors (ill have them finished by then!!!)
Post by Multi-Tech on Aug 20, 2006 21:33:22 GMT
Just a little update regarding the baggy bits. As i said in the last post i was renewing the form and vinyl on mine, which i have just finished ;D Here is some pic's
Post by redsunbeam on Aug 21, 2006 14:11:19 GMT
Looks good. Will have a go at mine once the kids have gone back to school and i have some more freee time.
