Post by PatMcCoy on Aug 29, 2006 18:48:09 GMT
Has any one got any photos of door rubbers on a saloon i can see As the sprayer took my old rubbers off and I'm not sure which way the profile should be,as the new ones dont show you
Post by PatMcCoy on Aug 29, 2006 18:48:43 GMT
And the boot rubber as well
Post by Deleted on Sept 18, 2006 18:51:31 GMT
Sorry Pat, I've not got an answer just the same problem! Does anyone have door seal fitting instructions they may be able to e-mail ? I've sussed the front door of my Saloon, but am struggling to work out the chinese puzzle of three different sections for the rear doors. Any help would be appreciated. Jeff "jeff@pontlliw.freeserve.co.uk"
Post by dorsetflyer on Sept 20, 2006 19:44:42 GMT
Post by lagain on Sept 26, 2006 21:07:34 GMT
If you are fitting remanufactured seals - good luck. I find it very irritating that some new parts are nothing like the originals. Surely if some one is going to the trouble of having parts made it is worth doing it properly. I tried to fit a new boot seal some years ago. I was sent a long length of rubber, with no moulded corners, it could never fit properly so I threw it away and have kept with the disintigrating original.
Post by Deleted on Oct 2, 2006 13:45:32 GMT
can you get new door rubbers then?? where from??
Post by dorsetflyer on Oct 2, 2006 15:11:20 GMT
Post by PatMcCoy on Oct 2, 2006 17:40:49 GMT
Post by davidg on Oct 2, 2006 20:29:37 GMT
Yes, i can supply all rubbers for the saloon or coupe, will save you the import duty and there is no VAT David Green
