Post by stan on Nov 21, 2017 23:16:23 GMT
The trouble with late night mechanics on the drive is eventually you will end up dropping something and never find it.
After removing the air filter unit (which must surely be spares from a English Electric Lightning jet!!) I lost the rear wingnut down the back of the engine into the vortex that swallows such things and no end of searching will bring it back.
After 40 mins searching old tool boxes comparing nuts that will fit, I gave up!
So please kind people do you know the thread size so I can get a replacement?
Btw changing the air filter turned into a 35 minute job trying all sorts of means to squash the swine in and worse fit it into the shell afterwards. Fortunately cunning use of wooden blocks and adjustable furniture vice did the trick.
Sorry I never qualified which nut, the small ones that hold the air filter element to the body and the one that hold the whole unit to the top of the block? Thank you
Post by djm16 on Nov 22, 2017 2:36:46 GMT
1/4 UNC?
Post by stan on Nov 22, 2017 7:57:53 GMT
Thanks is that a definite or a maybe? Blimey they are not cheap?
Post by stan on Nov 22, 2017 12:20:03 GMT
Does anybody know please? My car is beached at the moment , I dont want to be using duct tape to hold it in whilst I go to the local car factors!
Post by Simon H on Nov 22, 2017 12:42:31 GMT
1/4 UNC according to the parts manual. This is the wing nut that fixes the rear elbow to the long stud sticking out of the back of the air box. It's a wing nut on Mk1 and a hexagon nut on Mk1a, Mk2 and Mk3.
Post by johnwp5bcoupe on Nov 22, 2017 12:50:37 GMT
Small UNC ok to use Whitworth Stan
Post by stan on Nov 22, 2017 12:52:34 GMT
1/4 UNC according to the parts manual. This is the wing nut that fixes the rear elbow to the long stud sticking out of the back of the air box. It's a wing nut on Mk1 and a hexagon nut on Mk1a, Mk2 and Mk3. Thank you Simon and djm that confirms it then? Would you know about the bigger nut or wingnut under the unit that locks it down onto the engine block? Mines also missing?
Post by Simon H on Nov 22, 2017 12:55:46 GMT
I think the battery clamp wing nuts are the same. Perhaps you could 'borrow' one of those to to keep the car mobile? The larger nut is 5/16 UNF according to the book...
Post by stan on Nov 22, 2017 13:33:26 GMT
I think the battery clamp wing nuts are the same. Perhaps you could 'borrow' one of those to to keep the car mobile? The larger nut is 5/16 UNF according to the book... Thanks Simon its very kind of you to check for me. Managed to 'wedge' the filter in, enough hopefully to get it to the shop.
Post by Simon H on Nov 22, 2017 14:02:32 GMT
You'd be better going to an engineering supplier for the wing nuts. Or look out for an auto jumble at the weekend. Not sure where you are but there will be several stalls selling UNC and UNF fasteners at Huddersfield auto jumble this coming Sunday. Or Ebay if you can wait a few days, I just had a quick look and saw a pack of 5 X 1/4 UNC wing nuts for £2.35 with free P&P.
Post by stan on Nov 22, 2017 14:50:03 GMT
You'd be better going to an engineering supplier for the wing nuts. Or look out for an auto jumble at the weekend. Not sure where you are but there will be several stalls selling UNC and UNF fasteners at Huddersfield auto jumble this coming Sunday. Or Ebay if you can wait a few days, I just had a quick look and saw a pack of 5 X 1/4 UNC wing nuts for £2.35 with free P&P. Thanks Simon local shop didn't stop any only metric, ordered from fleabay and yes its that same one you saw. I am Lancashire based Huddersfield is not far from me handy to know for the future.
Post by johnwp5bcoupe on Nov 22, 2017 15:59:33 GMT
I will try again you can use Whitworth instead of UNC the pitch is the same on the smaller threads
