Post by stan on Dec 6, 2017 18:25:42 GMT
Hi can anyone please tell me if the P5B throttle return spring is the same as for the P5? Or is it the sort used on early landrovers?
Having trouble locating one?
Thanks
Stan
Post by harvey on Dec 6, 2017 18:41:59 GMT
Post by stan on Dec 6, 2017 19:45:50 GMT
Exactly my question? Is the 3 litre linkage same as the V8 ? Sorry to be clear its the 3 litre I have.
Post by harvey on Dec 6, 2017 20:00:03 GMT
Exactly my question? Is the 3 litre linkage same as the V8 ? Sorry to be clear its the 3 litre I have. My mistake, I misinterpreted what you wre looking for.
Post by stan on Dec 6, 2017 20:23:40 GMT
Exactly my question? Is the 3 litre linkage same as the V8 ? Sorry to be clear its the 3 litre I have. My mistake, I misinterpreted what you wre looking for. No problem thanks for taking the time Harvey appreciate it. :-)
Post by ozriderp5 on Dec 7, 2017 1:43:34 GMT
Mine has a generic looking spring with an adjustable arm on the butterfly shaft.
Post by stan on Dec 7, 2017 9:40:03 GMT
Mine has a generic looking spring with an adjustable arm on the butterfly shaft. View AttachmentThanks for that , there is one on the bulkhead attached to the pedal linkage? Thats the one I was considering changing? Tricky one to get to and take a picture of.
Post by ozriderp5 on Dec 7, 2017 10:26:46 GMT
Yep, it's sort of around the cable.
Post by Phil Nottingham on Dec 7, 2017 18:18:02 GMT
No the linkage is completely different on a V8 as it is mostly cable. Generic springs fit easily
Post by stan on Dec 7, 2017 18:25:51 GMT
 No the linkage is completely different on a V8 as it is mostly cable. Generic springs fit easily Thanks Phil ok will have to take it off measure and see what I can get. Thanks
Post by ozriderp5 on Dec 7, 2017 19:48:35 GMT
Post by stan on Dec 8, 2017 21:58:13 GMT
Is that inside? The one I am thinking is outside on the bulkhead next to the 500 rods and levers? They couldn't make it more overcomplicated if they tried?😂😂😂
Post by Phil Nottingham on Dec 8, 2017 22:01:58 GMT
That looks wrong - I will take a picture of our 3 Litre tomorrow - its been freezing/snowing all day today
Post by ozriderp5 on Dec 9, 2017 5:19:33 GMT
Is that inside? The one I am thinking is outside on the bulkhead next to the 500 rods and levers? They couldn't make it more overcomplicated if they tried?😂😂😂 That is the bulkhead, it runs from there to the linkages
