Post by Eric R on Mar 23, 2018 7:55:37 GMT
Can anyone suggest a good windscreen fitter in mid south UK please?
Post by tmulchro on Apr 15, 2018 17:48:25 GMT
Hi Eric
Did you find a windscreen fitter ? I need to replace the front and rear screen rubber seals (as they are leaking) and want to find someone who has done it before and knows how to seal them properly
Best Regards
Tony
Post by Eric R on Apr 15, 2018 21:06:56 GMT
No suggestion whatsoever in the forum but I have one possibility locally which I hope to follow up this week. You don't give your location. I have water lying in the driver's foot-well which I believe is the most likely place for front windscreens leaking, and also in the boot-well opposite the battery.
Post by tmulchro on Apr 15, 2018 22:07:15 GMT
I'm in North London Eric
I have water in the foot wells too
Let me know if you find someone - as it something that I don't fancy doing myself
I heard that someone who works for David Green can fit them, but I haven't followed this up
Regards Tony
Post by johnwp5bcoupe on Apr 16, 2018 7:47:14 GMT
Don't be surprised if you find there are rusty areas/holes in the bottom corners of both openings Tony, if so you will have to do these before fitting new seals.
Post by Deleted on Apr 16, 2018 7:48:01 GMT
I have noticed in the past that a couple of pages on facebook advertise fitting screens to these vehicles.I seem to recall a Youtube post as well.
Post by Eric R on Apr 16, 2018 10:30:31 GMT
Apart from water ingress I do see some ominous rust colour underneath the paint at the corner and yes, I had expected that that will need to be attended to at the same time as re-glazing.
Post by davewright on Apr 16, 2018 11:04:56 GMT
Sorry, I did not see this post originally. I am told that there is someone at Autoglass in Salisbury who can do these windscreens though I was told this a couple of years ago.
Post by Eric R on Apr 16, 2018 11:08:29 GMT
Autoglass came to see the car and said "sorry we cant do it".
Post by tmulchro on Apr 16, 2018 11:11:50 GMT
Found a recommendation ( from a senior member ) for this company in the threads - "Try: www.oldschoolwindscreens.co.uk they do all my screens and there work is top class " Expecting a call back I'm hoping I wont find any horrors when the seals are removed :-( T
Post by davewright on Apr 16, 2018 11:53:01 GMT
That's why I said you need to call the one in Salisbury as they can not all do it.
