Post by enigmas on Apr 13, 2018 0:13:27 GMT
Images in pages/posts/threads disappearing
If you were using postimages.org/ to host your pictures you may/will find that they are no longer visible! Your pictures are still in place though. It seems some technical/bureaucratic issue has transpired at this 'free' hosting service. Technically what it means is that there has been a change in the code to the link for your images. See below postimg.ORG domain is locked by Registry, no prior notice. While we hope to resolve the issue, we chose postimg.CC as our new home. Please update codes embedded in your websites.
The fix is straight forward. Look at the 2 links below. (I have purposely removed the first bracket symbol so that the coding is visible. img src="https://s6.postimg.cc/ejh0i5gsx/20180323_161159.jpg" alt=" "] img src="https://s6.postimg.org/ejh0i5gsx/20180323_161159.jpg" alt=" "] Note that cc has replaced orgThe Fix....go into Edit (of your post) and change the letters org for cc and your pictures will appear once again.
