Post by johnwp5bcoupe on Nov 12, 2006 16:54:00 GMT
Just out of curiosity I have two different types of Finishers the holes are a different distance apart the ones that are furthest apart have two plastic spacers and don't fit my 1969 seats so obviously the backs changed at some time? I have the correct ones for my seats just wondered about the history of the change? if anyone knows?
Post by Phil Nottingham on Nov 12, 2006 22:39:40 GMT
Early V8's had the same thick backs as the Mk3 3 litres - 1969 models had much narrower backs hence the different head rest brackets
Post by johnwp5bcoupe on Nov 13, 2006 7:18:40 GMT
Hi Phil I knew that about the seats, the finishers I mean are the ones that cover the seat pivots, I have a spare back in a different colour out of a slightly earlier car the backs are the same thickness as mine but the finishers are different as I described.
Post by Phil Nottingham on Nov 13, 2006 19:54:09 GMT
I am still not sure what you mean - is the fabric covered one or the stainless ones?
Post by johnwp5bcoupe on Nov 13, 2006 22:37:57 GMT
Hi Phil the two stainless steel ones
Post by Phil Nottingham on Nov 13, 2006 22:59:14 GMT
All the seat finshers I have got seem to be the same - the part numbers never changed from Mk3 to late V8's.
They have got plastic spacers and these are not listed at all.
I suggest they were drilled to fit on seat assembly so all would be slightly different?
Post by johnwp5bcoupe on Nov 14, 2006 7:13:52 GMT
Hi Phil that would not work if you re-drilled the ones that are furthest apart on the wrong back you would drill into the hinge I will send you some pics.
Post by Phil Nottingham on Nov 14, 2006 17:11:20 GMT
Odd - it just goes to show just how handbulit these cars were - no two are precisely the same!
I would like to see these as I have another set of old seats in a lock up which I have not looked at recently
