Post by johnwp5bcoupe on Nov 28, 2006 11:14:54 GMT
Has anyone a glue they can recommend to stick the door seals to the bodywork? I cleaned the doors and rubbers with acetone tried Evostick and Dunlop they don't hold very well
Post by Phil Nottingham on Nov 28, 2006 19:09:16 GMT
Supaglue is recommended but I do not know how long it will last. On my Land Rover I use 2 part fast set epoxy!
Post by johnwp5bcoupe on Nov 28, 2006 19:32:48 GMT
Hi Phil I understand Supaglue to join the rubbers but I don't fancy it to stick the seals to the doors
Post by Multi-Tech on Nov 28, 2006 23:01:25 GMT
John i use the Dunlop T1358 glue, we use for the interior work as well, its got a high temp melting point. The best way to use it is to put a coat over the door area and on the seal first, let this go off for 20mins depending on condition so it dry, then re coat the same area and allow the glue just to go off so its a little tacky then stick away.
Post by johnwp5bcoupe on Nov 29, 2006 7:17:41 GMT
Hi Barry thanks I will have a look which Dunlop I have tried if it's the wrong one I will give your suggested one a try, I used the same method on fixing but the glues I tried were useless! I will let you know how I get on
Post by johnwp5bcoupe on Nov 29, 2006 10:28:17 GMT
I have tried to find Dunlop Barry but they have sold out to Alpha Adhesives the new product is S1358 (min order 5lts) gave my local agent which is Peterborough they will only sell me a tin if he get rid of the spare tins! as he has none in stock! and has to buy 12 1ltr tins but he gave me some advise that Evo-stik 528 is the strongest impact adhesive on the market! so I will give that one a try
Post by Phil Nottingham on Nov 29, 2006 16:46:25 GMT
I did not know you still get that stuff - is it the old fashioned stringy, fumey stuff thats sticks anything forever!
Post by johnwp5bcoupe on Nov 29, 2006 18:21:30 GMT
After talking to a supplier of industrial adhesives with the intention to buy some Evo-stik 528 he advised me to try another product Bostik 2402 which in his opinion was a superior adhesive so he is sending me some, a litre is £27.47 including next day delivery I will keep you posted
Post by Phil Nottingham on Nov 29, 2006 20:04:53 GMT
Expensive!!
Post by johnwp5bcoupe on Nov 29, 2006 21:09:18 GMT
Yes I agree Phil but after buying 3 products that didn't work if this one works it's worth the money! the door seals are bad enough to stick but the boot one is even worse and it works out at 1.5 litres so I will have enough to do a friends Coupe as well as my own and still have enough for other bits that need sticking.
Post by Multi-Tech on Nov 29, 2006 21:12:06 GMT
Phil, thats the stuff its excellent for what we use it for. John should have said when you was on the phone, we buy it as 12 1ltr tins but i could have sold you one it would have been half the price
Post by Multi-Tech on Nov 29, 2006 21:12:43 GMT
oh and how did you get on with the carpet?
Post by johnwp5bcoupe on Nov 29, 2006 22:25:53 GMT
Hi Barry didn't like to trouble you! buy the time you wasted your time packing and posting and me paying for postage it seemed easier this way! PLUS I get the chance to try another glue!! I rang the English supplier a few times and left a message! if all else fails I will ring the German one I reckon 5.1 metres of carpet
Post by Multi-Tech on Nov 29, 2006 23:40:15 GMT
John it would have been no trouble at all, would of been glad to help. Remember for another time If you want i can check the measurements to make sure regarding the carpet?
Post by johnwp5bcoupe on Nov 30, 2006 6:58:01 GMT
Thanks Barry a second opinion would be good a lot of the pieces are around a metre in length so at 42" wide there is not too much wastage the gearbox tunnel is the worst bit of wastage there is a piece 33cm X 1.7m! I can make some rear over mats out of that piece, if I make some over mats for the front it works out at 6.2 metres
Post by Multi-Tech on Nov 30, 2006 19:23:39 GMT
Hi John only just checked the site so will look at my one at work tomorrow and let you know what we think
Post by johnwp5bcoupe on Nov 30, 2006 21:19:46 GMT
Thanks Barry
Post by Multi-Tech on Dec 1, 2006 20:52:02 GMT
Hi John had a measure up for you and would say that 5meters would be would be the amount we would order if we was to do the job, i would say order 5.5 meters to play safe or even 6 if you wanted to make the mats, (full set of mats use 1 meter) If you need anymore help just shout
Post by johnwp5bcoupe on Dec 9, 2006 10:30:31 GMT
Bostik 2402 works really well 1st coat dries in 5-10 mins stick another one on leave for 5-10 mins depends on temp, if it is a tricky moulding put a wet coat on before putting in place. It is a 2 part product very easy to apply not stringy so little or no mess
Post by Phil Nottingham on Dec 9, 2006 12:42:57 GMT
What colour is it?
Post by johnwp5bcoupe on Dec 9, 2006 13:38:16 GMT
Hi Phil if you spread it thin opaque to cream if you put it on thicker, it is so easy to spread I did all the door seals with 40ml any resedue I got off with panel wash.
Post by Phil Nottingham on Dec 9, 2006 20:33:48 GMT
Thanks must try to get some of this - how easy is it obtain?
Post by johnwp5bcoupe on Dec 10, 2006 7:58:01 GMT
Hi Barry just seen your reply thanks got lost in the glue still waiting for samples from Germany the UK one you gave me didn't do 100% wool Phil I will email details Hi John had a measure up for you and would say that 5meters would be would be the amount we would order if we was to do the job, i would say order 5.5 meters to play safe or even 6 if you wanted to make the mats, (full set of mats use 1 meter) If you need anymore help just shout
