Post by richardlamsdale on Jun 22, 2018 17:53:35 GMT
I'm finishing the re-wiring of my car, and I can't understand how the two bulbs that fit in the back on the speedometer and tachometer (Coupe) for illumination are earthed? The bulb holders just have a positive feed and fit in the back of the instruments, but the instruments themselves aren't earthed, so where does the earth feed come from?
I could run an earth to each of the mounting screws, but the loom doesn't have those and I don't recall these being there when I removed the old loom? The panel lights all worked, so they must have been getting an earth from somewhere.
Anyone have any ideas?
Post by Mike’S-a-loon on Jun 22, 2018 18:20:27 GMT
Speedo drive?
Post by richardlamsdale on Jun 22, 2018 18:23:15 GMT
Its a good thought, but it doesn't explain the tachometer earth - the two instruments aren't electrically connected.
Post by johnwp5bcoupe on Jun 22, 2018 19:50:06 GMT
I'm finishing the re-wiring of my car, and I can't understand how the two bulbs that fit in the back on the speedometer and tachometer (Coupe) for illumination are earthed? The bulb holders just have a positive feed and fit in the back of the instruments, but the instruments themselves aren't earthed, so where does the earth feed come from? I could run an earth to each of the mounting screws, but the loom doesn't have those and I don't recall these being there when I removed the old loom? The panel lights all worked, so they must have been getting an earth from somewhere. Anyone have any ideas? There should be Black wires on terminals/tabs under the thumb screws on the brackets holding the speedo rev counter Richard
Post by richardlamsdale on Jun 22, 2018 22:09:57 GMT
Ah, thanks John. My car must have been missing these since I bought it, but it makes sense.
Post by johnwp5bcoupe on Jun 23, 2018 11:15:17 GMT
Hi Richard I am trying to sort out a friends wiring after his car has been in a restores for a long time and both the Speedo and the Tach have a double black wire on the bracket under the thumb screws.
Post by richardlamsdale on Jun 23, 2018 22:30:48 GMT
Thanks John. I've now created something similar for mine.
