Post by holmesdale on Apr 24, 2019 18:32:39 GMT
Hi Guys, My parking pawl went about 10 years ago, but I'm looking to sell my saloon so I thought I should put it right, I see there's lots of good advice on changing the pawl, but I can't find a supplier.. Where do you get them from? Also supplementary problem, the box changes up to third at about 25 mph, should I tighten or slacken the kick down cable? thanks
Post by Sam Bee on Apr 24, 2019 21:52:18 GMT
You could try 'Norfolk Automatics'. 01682 218110 ask for Nigel.
Post by johnwp5bcoupe on Apr 25, 2019 8:49:22 GMT
There are a couple of BW35 experts on here in the uk Andy and Harvey and Vince in Australia and I am sure you will get the answers just wait a bit
Post by lagain on Apr 25, 2019 16:37:21 GMT
Changing into 3rd at 25 mph is about right on a light throttle. Have a look behind the air filter where the rod sits and the cable goes down into the box. There should be a rubber bush that the rod turns in, they can disintigrate. There should be a crimped bit of lead on the cable and, from memory, a one eighth gap between the crimp and top of the tube. Otherwise remove the sump to adjust the cable so that the valve is closed when at rest. However if the adjustment has not been mucked about with it may be OK
Post by eightofthem (Andy) on Apr 25, 2019 17:57:55 GMT
I have a park pawl here should you still be in need of one.
