Post by markymark on May 19, 2019 18:55:50 GMT
Hi All, I only have the original jack in my boot. Much though I have confidence in the strength of my jacking points I’m not sure the jack I have is in a condition I can trust. I was wondering what folks on the forum have in their boot for that crisis moment when I tyre goes flat? Any thoughts welcomed. Thanks, Mark
Post by lagain on May 19, 2019 19:39:21 GMT
It is not just the jacking point on the rear, it is the Y bushes, which can come apart when taking the weight of the axel. I would keep a compact trolly jack in the boot and lift the rear from under the spring fixing or under the drain bolt and under the centre chassis member at the front, where you may need a block of wood.
