Post by vetanari on Aug 1, 2019 12:54:16 GMT
Hi,
I've got a bit of a problem and I'm not sure if a. this has happened to anyone before b. if it has, what the **** to do about it
At the top of the gearbox dipstick on my p5b there is a block of plastic (looks a bit like a wine cork) that presumably is there to form a seal at the top of the tube The actual dipstick goes through the centre of this This block has come adrift from the top of the dipstick and is now firmly wedged in the tube leading to the gearbox. The dipstick is still running through the centre of it. The thing is stuck fast with nothing visible that I could get a grip of I'm worried that if I try to pull it out using the actual dipstick the bottom of the dipstick will either pull through the block or snap. Both these scenarios end with either bits of plastic or bits of dipstick landing in the gearbox
The car is (mercifully) off the road just now. My plan was to replace the gearbox. I think it may have got wind of this and sabotaged me!
So, any ideas folks?
V
Post by harvey on Aug 1, 2019 13:38:25 GMT
It's a common problem. If you have plans to replace the gearbox then as you'll have the dipstick tube removed, you can try to remove the rubber with the tube on the bench.
