jimmy
Rover Newbie
Post by jimmy on Nov 6, 2019 11:13:29 GMT
Has anyone used Evans coolant in there P5 coup , and if so how much to put in
Post by lagain on Nov 6, 2019 16:47:39 GMT
I think that the problem is that the Evans has to go into a dry system and it is very difficult to get all the water out of the P5. If you are rebuilding a car and there is absolutely no water that would be OK but otherwise best to stick with Bluecol. Probably similar to Silicone brake fluid, when I changed to that I had to get every drop of DOT4 out of the system and change all the rubbers.
