Post by David on Nov 23, 2019 9:26:29 GMT
CEM-DT156 PAINT DEPTH GAUGE FOR SALE "This compact & handy Professional Gauge is designed for non-destructive, fast and highly accurate/precise coating thickness measurement. The principal applications lie in the field of corrosion protection. Ideal for manufacturer, offices & specialist advisers, paint shops & electroplaters, chemical, automobile, shipbuilding and aircraft industries including light & heavy engineering. DT-156 gauge are suitable for laboratory, workshop & outdoor use. It works either on magnetic induction principle and on eddy current principle, depends on probe used. DT-156 uses only 1 probe for both ferrous & non-ferrous metal substrates. Probe can be selected manually or automatically. Non-magnetic coatings (e.g. paint, zinc) on steel. Insulating coatings (e.g. paint, anodizing coatings) on no-ferrous metals No-ferrous metals coatings on insulating substrates. Easy MENU operation system Statistics Display : AVG, MAX, MIN, S.DEV and Number of readings in work mode As new. £75 inc p&p UK only www.youtube.com/watch?v=-I1iWnsPc_4
