Post by p5andrew on Dec 6, 2019 21:39:31 GMT
I have recently acquired a P5B coupe. The fuel return pipe is currently (or was!) attached to the underside of the nearside sill using self-adhesive plastic clips. Clearly this is not correct but although I have owned a P5 previously it was a long time ago and I just cannot remember how the return pipe should be routed. Advice would be welcome.
Post by Sam Bee on Dec 6, 2019 22:50:43 GMT
The nearside sill is correct. The pipe is attached by a series of metal clips, as per photo, using self tapping screws, the holes for which should be observable. These are obtainable through the trade. . The pipe is led down the left hand side of the scuttle, in engine compartment, then fed between body and sub-frame, being clipped to the body, then to the sill, attached along the inside side, eventually over the wheel arch, as per the lines on the other side, to a grommet into the boot.
Post by p5andrew on Dec 8, 2019 15:43:43 GMT
Many thanks. That sounds much more sensible than the current arrangement on my car where it has been fixed to the underside of the sill using self-adhesive pads/clips which have let go and allowed the pipe to drop! I shall refix with the correct clips in the correct position all as you describe.
Post by Deleted on Dec 9, 2019 13:43:50 GMT
Mine has no return pipe. Its been cut off at some time,I think the run underneath has been removed. I suppose they reduce the risk of vapour lock,especially with the mechanical pump. I wonder if its worth replacing it?
