Post by cheese99 on Feb 14, 2020 15:06:40 GMT
Afternoon,
Is this a common mod with ventilated discs all round and general brake upgrade?
And are there any trusted garages that could do this on a P5?
Many thanks
Post by johnwp5bcoupe on Feb 14, 2020 17:58:33 GMT
The only one I know of uses a Jenson Back Axle
Post by Sam Bee on Feb 15, 2020 18:40:15 GMT
I am about to order new discs, for the front of course, which are drilled. They cool down quicker and are more efficient than plain standard discs.
Post by lagain on Feb 15, 2020 20:43:02 GMT
Afternoon, Is this a common mod with ventilated discs all round and general brake upgrade? And are there any trusted garages that could do this on a P5? Many thanks If any one finds a 'trusted' garage please let us know, I could write a (very long) book on the bad ones ! When set up properly the brakes work very well. It could be that with discs on the rear they would lock up too soon and would need a release valve, or something.
Post by enigmas on Feb 15, 2020 22:13:36 GMT
Not really likely George. Discs aren't self energizing like drum brakes and really require a larger brake booster for higher line pressure. As long as the caliper piston ratios are taken into account there won't be an issue. Mirror the caliper sizes/brake system front and rear to the Factory design of a similar sized vehicle. The Jaguar MK2 rear caliper assembly can be adapted to the Rover differential. The Jaguar handbrake mechanism will also hook-up to the original Rover assembly. The length of the Rover handbrake cross link arms at the rear needs to be lengthened byabout 1" to increase the mechanical ratio of the handbrake mechanism with the rear discs. The original front discs can be retained. Upgraded drilled and slotted discs can be substituted for the solid originals. or If you're in OZ a 1980s Ford Falcon diff (vented rotors, lower ratio differential gear set, LSD) will fit. A Rover club member in OZ did this conversion many years ago. He used the Ford stud pattern front and rear and fitting modern alloy wheels. He also drove the car from the East to the West coast of OZ and back. No mean feat!
Post by johnwp5bcoupe on Feb 16, 2020 9:25:03 GMT
Set up and maintained correctly all 4 wheels lock on a standard P5b brake set up If your fitting a larger?? engine I can possibly understand the need for upgrading.
Post by nz on Feb 20, 2020 5:37:55 GMT
***If you're in OZ a 1980s Ford Falcon diff (vented rotors, lower ratio differential gear set, LSD) will fit***
Hi. Hopefully Falcon uses a higher ratio (lower numerically) diff, or fuel economy would suffer.
Yes, a 4 wheel disc brake master cylinder should be used, as a disc /drum one has a one-way valve in the cylinder for rear drums. Paul. NZ.
