Post by fortnum1977 on Feb 18, 2008 15:54:08 GMT
Hello,
I drive a 1972 P5B Coupe and the driver's seat has collapsed. The adjuster handle to the left has completely freed up and is loose... the chair just falls back horizontally now. I have wedged a bucket behind me to keep it upright... that's what I call a bucket seat.
Are there any experts here who know what may be wrong with it... do I need to buy parts?? can I repair it??? etc...
Many thanks,
Chris
Post by johnwp5bcoupe on Feb 18, 2008 17:11:35 GMT
Chris remove the ss trim both side and see if the adjustable locking screws are in place first and the long locking rod is screwed into the large adjustable hexagonal locking pads
Post by Phil Nottingham on Feb 18, 2008 19:39:14 GMT
Parts should not be necessary - there is something on the Forum about the correct adjusting sequence
Post by johnwp5bcoupe on Feb 18, 2008 21:06:51 GMT
He has to check that the locking screws are there Phil before thinking of any adjustments often the screws fall out due to the threads stripping or just fall out
Post by Phil Nottingham on Feb 18, 2008 23:33:08 GMT
I was not disputing your comment merely adding to it
Post by johnwp5bcoupe on Feb 19, 2008 7:08:18 GMT
Me Toooooo Phil just trying to point him in the right direction
Post by fortnum1977 on Feb 19, 2008 10:10:08 GMT
cheers... yes there seems to be some loose screws inside those plates on either side... but I'm a bit worried 'cos I think the chair has been bodged up at some point. A screw fell out of it a while ago which was a self tapper... clearly not original.
The locking screws are in place though, I've had those plates off to take a look. Not sure about the 'long locking rod'... will inspect that soon.
Post by johnwp5bcoupe on Feb 19, 2008 13:29:39 GMT
Is there any torsion on the torsion bar?? this is probably where the self tappers came from if the seat back falls under it's own weight there is no torsion applied best to sort this problem first
Post by fortnum1977 on Feb 19, 2008 13:53:34 GMT
that's right, no torsion at all and the seat just falls back.
What do you reckon?
Post by johnwp5bcoupe on Feb 19, 2008 15:09:38 GMT
First check the threads in the seat frame make sure you can get 2 good screws in if the UNF threads have gone you may have to retap with metric you then have to put a spanner on the end of the torsion bar where the screws are and wind up the torsion bar maybe half a turn in the correct direction while holding the spanner you then under tension try and fit the 2 screws in the nearest hole if you have done it correct the seat should fly back to the upright position
Post by fortnum1977 on Feb 19, 2008 15:24:06 GMT
ok I think i understand but what are the UNF threads?
Post by Phil Nottingham on Feb 19, 2008 17:15:09 GMT
The last Imperial standard threads based on INCHES. The thread diameter is say 1/4" and UNF means Unified National Fine as opposed to UNC which has a course thread ie bigger pitch which is less threads per inch. The course threads are used in Allo etc
Metric/UNF nuts/bolts are not interchangeable although some AF spanner sizes are virtually equivalent
Without looking I think they may be 1/4 UNF (or 3/16th) on the seat which is very common and there are many on the P5 - a metric version nearest is 6mm which is actually smaller so the next size up will 8mm or 3/8ths
miguel
Post by miguel on Feb 19, 2008 17:42:23 GMT
Hi, This issue is important for me because in Portugal we use the metric system. When recently working in the Riley, I encounter problems with the spanner sizes. Although many are equal there are some sizes that dont fit exactly and that damages the bolts/nuts. I decided to buy a "English" (inches??) set. What size range should I look for? What´s UNC and what´s the difference to UNF? Thanks, Miguel
Post by johnwp5bcoupe on Feb 19, 2008 18:40:03 GMT
If you get a set of imperial spanners to cover these sizes you should be Ok 1/8, 3/16, 1/4, 5/16, 3/8, 7/16, 1/2, 9/16, 5/8, 11/16 and 3/4 there are a few more odd sizes but several metrics will fit have a look here www.vars.freewire.co.uk/tech/charts/spanners.htmAs Phil said UNF is Unified National Fine and UNC is Unified National Course there were so many standards used in England I can understand your confusion
Post by Phil Nottingham on Feb 19, 2008 19:50:22 GMT
Fortunately its not a P4 they had BSF/BSW on the chassis with a 55 deg fine and coarse thread respectivly - AKA Whitworth. The seats may have them of course. Electrics will have the small BA (British Association) threads and some pipe fittings use BSP British Standard Pipe!
Metrinch spanners/sockets fit both AF Metric/Imperial & Whitworth
Post by fortnum1977 on Feb 19, 2008 20:27:22 GMT
Correction - my seat sits upright but is completely floppy and won't take any weight. It doesn't, as I said earlier, fall down horizontal.
Post by johnwp5bcoupe on Feb 19, 2008 21:11:00 GMT
Parts should not be necessary - there is something on the Forum about the correct adjusting sequence That's a different problem as Phil quoted there is a correct sequence probably best read in a manual or from the forum there are several things to check compression tube dimension, adjusting the pad and locking rod etc etc Still check the screws in the squab mechanism
Post by fortnum1977 on Feb 19, 2008 22:23:49 GMT
compression?? tube dimension??? is this a chair we're talking about???
I've got the manual so will consult that... but as I remember, when I was trying to bleed my PAS box, that book was about as helpful as a kick in the b*lls...
Post by Phil Nottingham on Feb 19, 2008 22:34:01 GMT
Its quite a complicated set-up and gives stepless adjustment of the back by the twisting of a hollow tube that runs across the back. They are generally quite reliable but can sieze through lack of use/damp. They can also fall apart. They were used only on P6 Rover and Rover P5 Mk3's onwards so parts can be obtained if needed. The seat back is locked by pressing hard down on the big grey lever at the side of the cushion - you have tried this? Lifting up releases it. Adjust it so that it quickly returns upright without any help from fully reclining when lever is lifted up. The workshop manuals were not designed for novice owners but for trained mechanics and so assumes sometimes quite advanced knowlege. This said one is essential whether you DIY or give it to a modern mechanic who is used to throw way and fit new rather than repair a component
Post by Warwick (Ozcoupe) on Feb 19, 2008 23:37:55 GMT
The main thing to remember Miguel, is that UNF, UNC and Metric spanners are described in "AF" sizes. AF simply means "Across the Flats". If you measure the size of the bolt-head from one flat side of the hexagon across to the opposite flat side (across the flats), whether in inches or in mm, that's the size spanner you need.
Therefore you can usually make do with a 13mm spanner on a 1/2" bolt-head for example. If you have a bolt-head that measures 5/8" across, you need a 5/8" spanner.
Whitworth, being the grandfather of standardized bolt and screw sizes, is the odd one out. The size written on the spanner represents the size of the bolt shank, not the head.
A 1" AF spanner measures 1" across its jaws and fits a bolt that is actually nominally smaller since the bolt size is determined by its shank diameter.
A 1" Whitworth spanner however fits a 1" bolt. That is, the shank of the bolt is 1" in diameter. The head of such a bolt is very much bigger and so a 1" Whitworth spanner is huge since the jaws are much more than 1" across.
I hope that makes sense.
Warwick.
Post by fortnum1977 on Feb 20, 2008 9:41:19 GMT
Ok Phil, thanks for this advice. As i said, the back sits upright but can take no weight and the grey handle is completely free/loose/does nothing. So, what do you think I should try doing? thanks Its quite a complicated set-up and gives stepless adjustment of the back by the twisting of a hollow tube that runs across the back. They are generally quite reliable but can sieze through lack of use/damp. They can also fall apart. They were used only on P6 Rover and Rover P5 Mk3's onwards so parts can be obtained if needed. The seat back is locked by pressing hard down on the big grey lever at the side of the cushion - you have tried this? Lifting up releases it. Adjust it so that it quickly returns upright without any help from fully reclining when lever is lifted up. The workshop manuals were not designed for novice owners but for trained mechanics and so assumes sometimes quite advanced knowlege. This said one is essential whether you DIY or give it to a modern mechanic who is used to throw way and fit new rather than repair a component
Post by johnwp5bcoupe on Feb 20, 2008 10:52:14 GMT
The first thing to check is that when you operate the lever the hexagonal pads try to pinch the squab frame either side of the long slot? if it is trying? it could be that the adjust pad (the large nut on the tube) needs adjusting the start point is 18 11/16" (474.662 mm) if nothing is happening it could be the rod is rusted up! something may be missing (screws?) or broken? the principle is when you push the lever down the pads pinch the frame by pulling on the rod this can be adjusted on the pads either side but the tube must be the correct length first and the rod must run freely! put white grease on the threads and rod to save further problems
Post by fortnum1977 on Mar 3, 2008 13:32:36 GMT
Well, instead I picked up a set of all four seats from Enfield on Saturday for £180... and they are in great original condition.. the stitching is still fresh... look like they havn't been sat on... just a little dull after a long period of storage but can be brought up no problem.
The front seats are, however, thinner than my old ones.. the back of them I mean.
I know that the seats were redesigned at some point but thought it was the base.
Anyone know the deal here?
cheers
Chris
Post by Phil Nottingham on Mar 3, 2008 13:56:08 GMT
The thick back seats were for MK3 3 Litres and very early P5B's up to about Mid 69. They were changed to thin ones to give more legroom in the back especially with Coupes
Post by dorsetflyer on Mar 3, 2008 15:23:35 GMT
Phil, have you got your wires crossed on this one. I thought the thicker back seats were changed in 1969 to the thinner version to give more legroom in the Coupes and this standard of seat remained to the end of production in 1973
