Post by gerryp on Feb 29, 2020 18:55:16 GMT
Hi as any body got a serviceable 3 litre mk11 crankshaft to suite a DG auto gear box must be out of a late car suffice C
Post by djm16 on Feb 29, 2020 23:08:53 GMT
Would you like to share what went wrong with yours?
Post by gerryp on Mar 1, 2020 11:10:59 GMT
Thanks for interest I managed to buy a nut and bolt rebuilt engine but unfortunately it’s for manual or a Borg Warner 35 auto box
Post by harvey on Mar 1, 2020 15:56:35 GMT
Thanks for interest I managed to buy a nut and bolt rebuilt engine but unfortunately it’s for manual or a Borg Warner 35 auto box No help to you, but I think I'd convert to a BW35......
tonys
Post by tonys on Mar 1, 2020 16:49:12 GMT
Funny, that was my first thought (convert to BW) as probably much easier to source. However, I wasn't sure what else was involved as I did read that they changed the diff ratio on the MK111 autos but whether that was just to bring it in line with other P5s I don't know and they fitted a separate transmission oil cooler.
Post by gerryp on Mar 1, 2020 17:18:46 GMT
I did think of changing gear boxes but there is a lot work involved i hope to source a crankshaft at the worst way I could use my one but i would sooner do a straight engine swap instead of taking my one apart
Post by enigmas on Mar 1, 2020 19:52:13 GMT
If you have a really good (MK3) engine I truly wouldn't be mucking about swapping the crankshaft with something of unknown condition/serviceability to fit a DG automatic unless you want to thoroughly rebuild the bottom end of the engine. It will definitely lead to tears. Truly it's much easier to fit a BW35 (upgraded) to the latest specifications or at least P5B equivalent to the engine.
As for the diff ratio, the 3.5 in the MK3 really is too tall for the weight of the car making them very sluggish to drive. A 3.7 or most likely what you have (3.9?) on the car is more suitable. It would also be definitely more responsive and lively to drive especially if you have Harvey or someone of similarly knowledgeable setup a more current valve body in the BW35. This will provide the car with part throttle downshifts at light throttle settings.
There's also no shortage of BW35/40 transmissions, rebuild kits and parts. They're also easier/cheaper to rebuild than a DG trans. Using a floor mounted selector is easiest/most straight forward but you can adapt it to a column selector if you really have the desire and patience. You'll also need to fabricate or adapt a rear trans mount and a suitable linkage for the transmission kick down cable.
There's more than enough expertise on this forum to guide you through the process.
Post by gerryp on Mar 2, 2020 10:31:44 GMT
Thanks very much for your comments and help I’ll give that some serious thought all the best Gerry
Post by Phil Nottingham on Mar 2, 2020 11:28:29 GMT
The diff ratio for the DG box is 3.9:1 - the 3.54.1 was used with the BW35 and manual box on the Mk3 and all the V8s. The column change pattern on the BW35 is the "modern" PRNDL on the Mk3 on
Post by djm16 on Mar 2, 2020 23:45:10 GMT
If the crank fits a BW35, then I believe it will be a MkIIc or MkIII motor. In which case the crank journals may well be different. I know for a fact that the rear main seal dia is different between MkIIb and NkIIc. I expect Phil will confirm re the journals too.
Post by gerryp on Mar 3, 2020 16:37:03 GMT
The problem I have is I have a mk11 3litre auto with a Dg auto box I’ve got a rebuilt 3 litre engine from a mk111 the crankshaft will match a Borg Warner 35 and a manual gear box but not a Dg auto box so if could get a late mk11 crankshaft I would fit to my rebuilt engine but the crankshaft I need must be from a late mk11 thanks for input on this issue
Post by gerryp on Mar 3, 2020 16:57:07 GMT
I also understand that the crankshaft in the mk11sufex c are the same as a mk111
Post by djm16 on Mar 4, 2020 13:46:23 GMT
I may be wrong, but I think that what you are asking is impossible.
The MkIIC and MkIII cranks have larger journals, and are designed for the BW box. Mk I, MkIIa&b have smaller crank journals and fit a DG box.
To my knowledge there is no larger journal crank fitting a DG box.
As I said, I may be wrong.
Post by gerryp on Mar 4, 2020 16:29:40 GMT
Hi thanks again for your help my car is a mk11 1966 coupe chassis ending C engine number ending in C l have a rover parts book it my be wrong but it shows crankshaft suffex C and mk111 the same size journals my engine tired but useable I was hoping to get a crankshaft from a late mk11 auto which would take a re grind to fit in my re built mk3 engine at the worst way I could use my original but that means the car would be off the road a lot longer hope that makes sense
Post by enigmas on Mar 4, 2020 20:37:14 GMT
Gerry unless the conrods, piston weights and crankshaft weights are all the same engine to engine, fitting an odd ball crankshaft will affect the engines dynamic balance factor. The 6 cyl engines are supposedly finely balanced. If you manage to fit the non-original crankshaft to the engine the fine balance associated with the 3 litre may be lost. There's never a cheap & easy solution to doing what you want to do.
Post by gerryp on Mar 4, 2020 20:57:12 GMT
Thanks for your input it looks like iam back to the drawing board it my be a case of selling my re built engine and putting the funds towards rebuilding my original engine
Post by djm16 on Mar 4, 2020 23:11:20 GMT
Do you know what has been done to the "rebuilt" engine?
Rather than selling it, you might be better off stripping it and re-using some of the expensive parts like pistons, cam-bearings (especially cam bearings), oil pump. Worth inspecting the heads on both to see which has been skimmed the least, which inlet manifold has the least corrosion, and so on.
Of course, if "rebuilt" just means re-bore and new big ends, then your plan to sell is good.
You sound like you already know that a well done complete rebuild of a 3-litre is not trivial either financially or in time taken.
Post by enigmas on Mar 5, 2020 4:27:14 GMT
I'd be watching DJM16s comprehensive 3 litre engine rebuild with renewed interest & enthusiasm Gerry. Do you need that degree of stress & expense in your life. I still believe the easiest option is to use the BW35 transmission with the MK3 engine for the reasons outlined earlier in this thread.
Post by gerryp on Mar 5, 2020 6:52:41 GMT
Thanks to you all for your help and advice I’ll keep you posted what I do and how I get on
