henry
Post by henry on Apr 12, 2020 14:25:38 GMT
Having finally found a decent knowledgeable mobile welder in Rochester, the 3 passenger side sills are on the car, although it turned out that during her re-commission 20 years ago, outer sills were welded onto the original rotten sills.
I want her back on the road, but I also want her modernised, so does anybody know if a turbo diesel p5b exists? Only I'm toying with the straight 6, 3 litre turbo diesel engine and box from a BMW X5, as it's a heavy car, so that set up will be used to moving 2 tonnes of metal, plus of course a 5 or 6 speed tiptrobic auto box will help.
These are cars after all, and as such should be driven on the road as much as possible.
Post by Brendan69 on Apr 13, 2020 14:03:29 GMT
Sounds like a great project and plan. I hope you manage it well and look forward to reading all about it. Go for it buddy and make it happen as i am sure these days anything can be made to fit anything with some fettling. Make sure you follow it through with a good brake upgrade too and possibly the rear diff may or may not need some tweaks also.
Good luck
henry
Post by henry on May 7, 2020 6:34:19 GMT
Jensen interceptor axle to have discs all round
