thor64
Post by thor64 on May 3, 2020 17:17:27 GMT
To get to the plunger you need to pull the rubber block from the two input terminals, this allows you to undo the two nuts that hold the points assembly together. Remove the metal spring plate; the Bakelite insulator; lift off the electro magnet contact and the right side input terminal. Now lift off the plastic points spring plate; the spring metal top-point and the left contact terminal. Then lift off the last insulating block. This leaves the plunger exposed. Carefully pull the plunger out of the electro magnet and examine. You can also see what shape the points are in. Having cleaned up everything replace all in the reverse order. Be careful when dissembling and reassembling as there are two insulating tubes surrounding the pins, these can be damaged and need to remain in good shape. Test the horn, they are very loud and scarred of our local flock of crows.
